06.03.2025, 08:11
		Please see our new Modbus profile app. Manual JSON creation is finally over.  You can easily create Modbus profiles and upload them to LM profiles. You can also edit live Modbus device and directly send changes to it. No need to remove and add devices again. The app is just profile creator/editor. Any work must be saved either to LM or as file on the PC.
If no register selected or only one, then only Add mapping will be visible. If more then one register is selected, then the fallowing options are present:
See the documentation for description of each parameter.
Editing live devices is a new features and we highly advice to make a backup before
Installation: On the main apps screen click the + icon when logged in as admin. Click the menu in the top left side and select "Install from file". Enable "Allow to install package without signature" option.
- Import profile of live device already added to LM Modbus tab.
 - Import profile from profiles in LM.
 - Import JSON profile from PC.
 - Edit device global parameters.
 - Save device will save it ether to live device(if live device is edited) or to profiles (if imported from profiles or JSON).
 - Download profile to PC in JSON format.
 - Link to documentation.
 - Link to this thread for help.
 - Actions - see below.
 - Edit local parameters of register. The same action will happen by simply clinking on register table.
 - Duplicate a register, see below.
 - Delete register.
- Add new registry mapping
 - Duplicate all selected registers
 - Delete all selected registers
 - Shift selected address by a given number
- The number which duplicated object address will be added to original value.
 - If selected read_offset is changed instead of address.
 - Specify the text which should be replaced in object name.
 - Specify the text which will replace text from point 3.
