Threads: 67
Is there any way to edit group addresses one by one when copying custom widgets?
In some projects I need to use multiple termostats but group addresses don't have a fix offset between zones, so I can't use replace objects...
Threads: 30
You will need to do it the old way and make more custom widgets and change groups for them one by one.
Threads: 15
As I understand, the cloud service is now supported. Meaning the LM app on my phone, should be opening the Vidu app directly (when set in the user access tab as default homepage).
But my phone still opens up in Mosaic everytime. Tried changing password for the user, setting the mosaic access to partial (lowest), and remembering to update cloud everytime. No success. Am I missing something?
Threads: 48
@jmir
1. Cloud status can be seen when opening the main menu. We will probably add another status indicator to the menu button.
2. Unfortunately there's no easy way of determining where a user performs a touch action or scrolling.
3. Scrolling is not possible if touching near the mover control. This will be fixed in the next version.
@PolymorphedCust
Close cloud Mosaic and go to cloud settings (gear icon). There you can select the default app when logging into cloud.
Threads: 30
Threads: 30
Threads: 4
using the "send fixed numeric value" widget even though the control accepts "any numeric value" does not allow the use of a one-bit dtp
Threads: 30
Threads: 30
No as you can achieve exactly the same with a switch widget
https://app.screencast.com/VOFPbkgE6mpVT
Threads: 30
You cant sent: 2,3,4,5... to a boolean object
