Push notifications
In the past i used the app Push notifications to test sending push messages.
But now it doesn't work anymore.
When i hit the send button its grayed out and i see a moving circle (for long time). But nothing happen.
I already:
- checked the settings
- deleted the app from my iphone and re-installed. Weird thing is that i see and old the following data in de push app (Apple iPhone13,3 iOS 14.7.1). But i have a newer phone and newer os.
How to start solving this issue?
How to register my new phone of check its right registered?
Which iOS version do you have?
(21.07.2023, 13:36)Daniel Wrote: Which iOS version do you have?
16.5.1 ©
Iphone 12 Pro
It worked for me on 16.5 will upgrade to latest
Worked fine for me
(21.07.2023, 14:52)Daniel Wrote: Worked fine for me
thats no solution  Wink
can i re-add my phone or my lm to the cloud account, or can i debug the process to check where its gone wrong?
As long we can't recreate the issue we can't solve it. Make sure that you are on the same local network as LM while adding it. If LM wasn't added to Push app, in mobile app disable push notifications, save edit again enable push notifications and save.
Make sure to use latest push app and LM cloud.
May I ask you if you have changed the name of the logic?
I have this problem if I changed the name.
Best regards Cristian
My name: LogicMachine
solved: removed and reinstalled the push notification app and it works again.
Can someone please send me the Push Notification ipk?
thank you in advance.
Why would you want the Push notification ipk? The new solution with LM Home doesn't need it.
https://kb.logicmachine.net/notification...fications/
It would be nice to have token free/send to all tokens push notification so that it sends it all the devices that are logged in to the server with the app. Personally I like the option of tokens because then you can customize push notifications to diffferent devices.
