KnxNet/IP - bug ?
Exclamation
this is a few (low-level) questions about the KnxNet/IP implementation on Logic Machine 5.
I too a look at UDP-packages in Wireshark while connecting to LM5 with ETS5, and found some anomalies.
1) In system settings -> KNX Settings, I specified that I want EIBNet/IP Tunnelling. However, LM5 keeps sending ROUTING_INDICATION packages ?
2) When doing a CONNECTIONSTATE_REQUEST, the CONNECTIONSTATE_RESPONSE  should contain one of the status codes:
E_NO_ERROR = 0x00,
E_CONNECTION_ID = 0x21,
E_DATA_CONNECTION = 0x26,
E_KNX_CONNECTION = 0x27
However, LogicMachine replies with code 0x15, which is an unknown status. Output from WireShark:
Request:
Frame 729: 58 bytes on wire (464 bits), 58 bytes captured (464 bits) on interface 0 Ethernet II, Src: Giga-Byt_28:b3:64 (fc:aa:14:28:b3:64), Dst: OpenrbCo_26 (00:1b:c5:00:10:26) Internet Protocol Version 4, Src: 10.20.25.30, Dst: 10.20.25.123 User Datagram Protocol, Src Port: 52989, Dst Port: 3671 KNXnet/IP     Header         Header Length: 0x06         Protocol Version: 0x10         Service Type Identifier: CONNECTIONSTATE_REQUEST (0x0207)         Total Length: 16 octets     Body         Communication Channel ID: 1         reserved: 00         HPAI: Control endpoint             Structure Length: 8 octets             Host Protocol Code: IPV4_UDP (0x01)             IP Address: 10.20.25.30             IP Port: 52988 HEX: 0000   06 10 02 07 00 10 01 00 08 01 0a 14 19 1e ce fc
Response:
Frame 730: 60 bytes on wire (480 bits), 60 bytes captured (480 bits) on interface 0 Ethernet II, Src: OpenrbCo_26 (00:1b:c5:00:10:26), Dst: Giga-Byt_28:b3:64 (fc:aa:14:28:b3:64) Internet Protocol Version 4, Src: 10.20.25.123, Dst: 10.20.25.30 User Datagram Protocol, Src Port: 3671, Dst Port: 52988 KNXnet/IP     Header         Header Length: 0x06         Protocol Version: 0x10         Service Type Identifier: CONNECTIONSTATE_RESPONSE (0x0208)         Total Length: 8 octets     Body         Communication Channel ID: 1         Status: Unknown (0x15) HEX: 0000   06 10 02 08 00 08 01 15
3) I tried to perform a line scan in ETS5, but no devices show up. I haven't analyzed the traffic (yet) for this issue.
I am currently implementing a KnxNet/IP client, which is why I stumbled across these issues.
1. It will always send telegrams to Routing if IP features are enabled
2. Looks like a bug, will fix
3. Are you connected to a KNX/TP gateway via Tunneling?
Yes, I am connected via Tunnelling.
- Øyvind
