problem with 4g modem
#21
Post what you have in System config > Status > System log.
Thank for the quick reply.
Here it goes.
What LM hardware model are you using?
LM5p2-RIO3LTE
LM5M3CV15xA23010267
Do you have 3G/4G connection enabled? If it's disabled then the on-board modem won't be initialized.
It was disabled. When we try to enable it the LM stops responding.
This most likely caused by LM using mobile connection gateway instead of Ethernet.
Follow this guide if you only need SMS without 3G/4G: https://forum.logicmachine.net/showthrea...7#pid33127
It worked. Thanks!
I still have a strange situation. In the alert I still get "SMS handler lost connection" but the SMS are getting through. I only happens with a card from one provider. Using a card from a different provider it doesn't happen.
Modify AT:run() function in the user library as follows and post what you get in LM Logs tab.
function AT:run()
  local res, err, cmd, pos, sms
  res, err = self:read()
  if err then
    if err ~= 'timeout' then
      log('run error', err)
    return err == 'timeout'
  -- check for incoming command
  if res:sub(1, 1) ~= '+' then
    return true
  pos = res:find(':', 1, true)
  if not pos then
    return true
  -- get command type
  cmd = res:sub(2, pos - 1)
  -- check only for incoming sms
  if cmd ~= 'CMTI' then
    log('run cmd', cmd)
    return
  -- read from sim
  sms = self:incsms(res)
  -- sms seems to be valid, pass to handler if specified
  if sms and self.smshandler then
    self.smshandler(sms)
  return true
Here goes the log.
Change the same function as follows and see if it helps.
function AT:run()
  if err then
    return true
  if not pos then
    return true
  -- get command type
  if cmd == 'CMTI' then
    -- read from sim
  return true
I have the LM with the built-in LTE modem. It has been configured, so it is only used for SMS, while the RJ45 port is used for all IP traffice.
I have created the standard scripts according to the guide, and I can send SMS without any problems. This works very stable. However, when I try to send a SMS to the LTE modem, then nothing happens. An example of SMS is "W 1//1/9 false" without the quotes to turn off something. I get no response on read. My sender phone number is allowed in the script, and I have tried both with and without country code.
I hope you can provide some temporary changes to the script, so I can find what I have missed.
Do you have anything in LM Alerts tab? Messages from all numbers are logged there.
Yes, there are messages. See screen shot with todays messages, where I tried off instead of false, but with same result.
Make sure that the number is specified in the script the same way as in the alert between [].
Modify the handler function in the resident script as follows and post what you get in Logs tab:
handler = function(sms)
  -- sms from known number, call parser
  if table.contains(numbers, sms.sender) then
    log('incoming sms', sms.sender, sms.data)
    parser(sms.data, sms.sender)
    log('unknown number', sms.sender)
For on/off use 0/1 or true/false.
I saw that the + sign in front of the country code was missing in the alert log, so I tried to remove the + sign and still country code number. That worked, and I have now for the first time received a response on a read SMS.
If I reboot the LM, and I send one SMS everything works fine. Both read and write. However, the next SMS send does not appear in the Alerts. Only if I reboot LM, it works correct for one single message. After a reboot it actually picks up the previous waiting message and responds.
I am using LM reboot functionality - no power recycle.
Is the resident script configured correctly with 0 sleep time?
Yes, see screen shot. The Generel Timer also shown is actually your staircase example with my own add ons.
This is my normal CPU and memory stats:
In the user library add logging to the AT:run() function:
function AT:run()
  log(res, err)
Then check what you get in LM Logs tab.
I opened the user library and added the single line "log(res, err)" saved and tried again. Then everything worked smooth. Then I commented out that line and it still works fine with  immediate reply.
Sorry for all this - I do not know why it did not work before. But it is working fine now. And I am glad that I now know where to add a log statement to gain more info in case of future problems.
Thanks and enjoy your weekend.
Update: after a LM reboot the same faulty behavior came back with only processing one message and then it stops. I will try to get some log info.
I have now tried editing log on and off + reboot, and I cannot find a pattern in the behavior. Only thing is that it generally seems to work better when the log writing is enabled, which makes no sense to me. I cannot go with this, because the log will be flooded with messages, as it issues a timeout message every second.
I never see any error messages in the log. Only many timeouts and now and then processing of a message. See screen shot.
