Syncing doesn't work on cloud
hello
Remote connection What router port should i need to open on his home router?
Syncing doesn't work for me in the cloud. Thanks
TCP 443 and 8883, and remember to set gateway and DNS, I don't know what error code 14 is-
Make sure that LM has valid gateway and DNS settings in System config > Network > Interfaces > eth0.
See if you can ping remote.logicmachine.net from System config > Status > Network utilities.
(01.10.2025, 07:18)admin Wrote: Make sure that LM has valid gateway and DNS settings in System config > Network > Interfaces > eth0.
Hello, I get a ping. Regards.
Ping remote.logicmachine.net or 168.119.164.110
(03.10.2025, 10:58)Daniel Wrote: Ping remote.logicmachine.net  or 168.119.164.110
hi i get ping attached
Thanks, the problem is solved.  Wink  I disabled the firewall And the connection was made & synchronization i turned the firewall back on router and then still connected Smile. Thanks for all the advice, best regards
