Syncing doesn't work on cloud
hello
Remote connection What router port should i need to open on his home router?
Syncing doesn't work for me in the cloud. Thanks
TCP 443 and 8883, and remember to set gateway and DNS, I don't know what error code 14 is-
Make sure that LM has valid gateway and DNS settings in System config > Network > Interfaces > eth0.
See if you can ping remote.logicmachine.net from System config > Status > Network utilities.
(01.10.2025, 07:18)admin Wrote: Make sure that LM has valid gateway and DNS settings in System config > Network > Interfaces > eth0.
Hello, I get a ping. Regards.
Ping remote.logicmachine.net or 168.119.164.110
(03.10.2025, 10:58)Daniel Wrote: Ping remote.logicmachine.net  or 168.119.164.110
hi i get ping attached
Thanks, the problem is solved.  Wink  I disabled the firewall And the connection was made & synchronization i turned the firewall back on router and then still connected Smile. Thanks for all the advice, best regards
Only outgoing ports are needed, you could add exception in your firewall. You can block all incoming ports.
