Logic Machine Communication - HTTP
Star
Hello, I would like to know, how can I take information from an HTTP page from the logic machine? Big Grin
http://w3.impa.br/~diego/software/luasoc...ml#request
If you just need a simple datafield you can also use:
123456789101112131415161718192021
require('socket.http') socket.http.TIMEOUT = 5 -- Get data from website local data = socket.http.request('http://openrb.com') -- Check if data is received if not data then     log('No data found')     return end -- Find your data for i in string.gmatch(data, '<body>.-</body>') do     if i ~= nil then         searched_data = i:match([[<h2>(.-)</h2>]])         if i ~= nil then             log(searched_data)         end     end end
Hi, Erwin van der Zwar:
Thanks for your help. Yes, it is a simple data capture, use your code but it is not registering anything to me.
The data is now fetched between <h2> </h2> fields but i don't know the fields in your html mark-up so you have to check that and change it to those..
log(data) to see your complete reply from your url source.. or right click your source in the browser and select 'view source code' to see the structure of the site you read..
Check is gateway and DNS are set in network config.
I adjusted the sample to a (tested) version to fetch all the main topics from this forum
12345678910111213141516171819202122232425
require('socket.http') socket.http.TIMEOUT = 5 -- Get data from website local data = socket.http.request('http://forum.logicmachine.net') -- Check if data is received if not data then   log('No data found')   return end -- Find your data for i in string.gmatch(data, '<body>.-</body>') do   if i ~= nil then      for j in string.gmatch(i, '<a href="forumdisplay.-</a>') do         if j ~= nil then            searched_data = j:match([[">(.-)</a>]])            if searched_data ~= nil then               log(searched_data)            end         end      end   end end
It works, thanks for your help. Big Grin
