All data in the database is gone after an alert
Hi !
In my environment I had my LM running for over 3 years.
Yesterday, for the first time all data in the database was gone and all objects and scripts are lost.
I can see alert log but there is no other log or error log.
Have you ever experienced this ? How can I avoid it from happening?
Most likely a problem with the microSD card in LM. Run this script once and post what you get in Logs tab:
files = io.ls('/data/dbfail/') log(files)
Thank you for looking into the inquiry!
This is what I got after executing the code.
Run this and post the results:
res = io.readproc('ls -l /data/dbfail/') log(res) log(io.readfile('/data/dbfail/1.log')) log(io.readfile('/data/dbfail/2.log'))
Thank you admin : ) This is what I got !
It looks like you have a power fail when LM was saving the database to disk.
Run this once then reboot LM:
os.execute('cp /data/dbfail/2.db /data/storage/scada.db')
See if your objects and scripts are restored.
(03.10.2025, 08:39)Hadeel Wrote: Hi !
I installed my LM for a small project approximately three months ago.
About one month ago, the LM began rebooting every morning at irregular times, typically between 5:45 and 6:15.
The issue is that yesterday I was able to see valid trend data, but today—after the reboot—the trend history from yesterday is missing, and only constant values are displayed.
I replaced the LM with a new unit, but the behavior remains the same.
Could you please advise on the next steps to resolve this issue?
You probably running out of memory and this is why LM reboots. Check what could be the reason, System load app may help.
(04.12.2025, 08:29)Daniel Wrote: You probably running out of memory and this is why LM reboots.  Check what could be the reason, System load app may help.
Okay, but if the LM stopped me from creating trends, how would I end up running out of memory?
When I create trends, I don’t get any alert that I’m running out of memory.
Trends is not the only thing which use memory.
Check your event scripts, there might be a loop between scripts somewhere.
I only have two scheduled scripts with some IF conditions.
I haven’t seen any loops here.
Could you give me a checklist of what I should review?
Send me your backup to PM. Use some file storage tool and drop a link.
(04.12.2025, 09:42)Daniel Wrote: Send me your backup to PM. Use some file storage tool and drop a link.
I also meet the same problem but it happen frequently. Each time, I use the backup file to restore it so I dont really know it happen when the power is lost or not, all database is lost after 1-3 months. I try to replace a new Micro SD card, use the latest firmware but the problem still happen. The next time, I will run those code and send you the log, is it?
Might be a different hardware issue. Run the script and post what you get.
I will try to run the script and post it here when it happen again (Sadly I restore the data from backup file so it has no log yet)
Restoring a backup does not affect these logs. This can only happen if you do a full recovery.
(03.10.2025, 09:55)admin Wrote: Most likely a problem with the microSD card in LM. Run this script once and post what you get in Logs tab:
Today all the database lost again, I run this code but got "nil" in log
Which firmware version do you have?
(09.03.2026, 08:06)admin Wrote: Which firmware version do you have?
Sorry for late reply, here is the firmware
[Image: image.png]
