Min/Max last 24h
Hi!
I have a copuple of temperature and wind speed sensors attached to my Wiser4KNX and i would like to present min and max temp and wind speed for the last 24 hours. Anyone who can point me in the right direction?
You can try this way, log your object for a day and then use this script, change logaddress and pastTime as needed.
logaddress = '32/1/3' pastTime   = 60*60*1  --in seconds addr = grp.find(logaddress) time= os.time() - pastTime objects = db:getall('SELECT dataraw, logtime, datahex FROM objectlog WHERE address =' .. addr.id .. ' AND logtime >'.. time ) local result, value = 0,0     for _, objvalue in ipairs(objects) do   value = busdatatype.decode(objvalue.datahex, addr.datatype)           result = math.max(result, value)    end log(result) --max     for _, objvalue in ipairs(objects) do   value = busdatatype.decode(objvalue.datahex, addr.datatype)       result = math.min(result, value)    end log(result) --min
Thank you, seems to work fine!
I tried to change to mat.min too, but i didnt get a negative value, just 0,0, even though it has been colder during the last couple of nights. Any ideas?
Check the logs and see if your sensor actually logged negative value. It works for me with negative.
Max:
result = -math.huge for _, objvalue in ipairs(objects) do   value = busdatatype.decode(objvalue.datahex, addr.datatype)   result = math.max(result, value) end log(result) --max
Min:
result = math.huge for _, objvalue in ipairs(objects) do   value = busdatatype.decode(objvalue.datahex, addr.datatype)   result = math.min(result, value) end log(result) --min
