Hello, I would like to know, how can I take information from an HTTP page from the logic machine?
Logic Machine Communication - HTTP
31.03.2017, 14:08
31.03.2017, 14:22
If you just need a simple datafield you can also use: Code: require('socket.http')
socket.http.TIMEOUT = 5
-- Get data from website
local data = socket.http.request('http://openrb.com')
-- Check if data is received
if not data then
log('No data found')
return
-- Find your data
for i in string.gmatch(data, '<body>.-</body>') do
if i ~= nil then
searched_data = i:match([[<h2>(.-)</h2>]])
if i ~= nil then
log(searched_data)
endErwin
31.03.2017, 17:50
Hi, Erwin van der Zwar:
Thanks for your help. Yes, it is a simple data capture, use your code but it is not registering anything to me.
31.03.2017, 19:18
(This post was last modified: 31.03.2017, 19:24 by Erwin van der Zwart.)
The data is now fetched between <h2> </h2> fields but i don't know the fields in your html mark-up so you have to check that and change it to those.. log(data) to see your complete reply from your url source.. or right click your source in the browser and select 'view source code' to see the structure of the site you read.. BR, Erwin
01.04.2017, 10:09
Check is gateway and DNS are set in network config.
01.04.2017, 21:35
(This post was last modified: 01.04.2017, 21:35 by Erwin van der Zwart.)
I adjusted the sample to a (tested) version to fetch all the main topics from this forum Code: require('socket.http')
local data = socket.http.request('http://forum.logicmachine.net')
if not data then
return
-- Find your data
if i ~= nil then
for j in string.gmatch(i, '<a href="forumdisplay.-</a>') do
if j ~= nil then
searched_data = j:match([[">(.-)</a>]])
if searched_data ~= nil then
log(searched_data)
endBR, Erwin
04.04.2017, 17:31
It works, thanks for your help.
