Dali and 1wire tab in LM5L
I have neither Dali nor 1-Wire in my LM5. Can I hide these tabs somehow?
Thank you
No you can't ... at least not without manipulating the core.css, i would not advice to do that ..
But why do you even want that ???  They are not on front-end, so you could just ignore them ...
You can remove genohm-scada-dali/w1 packages from system config > system > packages
Yes offcource on LM you can do that (:
The removal of any tab is not possible for HL/SL users as we don't support the option to remove packages..
Thank you for your reply. But I can't remove these packages because lm5ex depends on them.
No packages removed. Collected errors: * print_dependents_warning: Package genohm-scada-dali is depended upon by packages: * print_dependents_warning: genohm-scada-lm5ex * print_dependents_warning: These might cease to work if package genohm-scada-dali is removed.
Then you'll have to live with it until new FW is released Smile
OK, thank you.
Dali and 1wire tab is not problem. The only reason I want to hide it is to do the installation site as simple as possible. Now I have to remember "There's not a Dali at the device".
