Threads: 15
I have 1 LM on my office and 1 on my house.
Is it possible to create a connection between them and exchange information?
I would like to get some readings and even be able to send a command if required.
Threads: 34
Admin, correct me if I'm wrong.
Instead of an external MQTT broker, I guess you could use the built in broker on one of your LM.
Connect both LM to the same ZeroTier network.
Threads: 48
Yes, ZeroTier is another option.
If both LMs can already reach each other over VPN then you can run MQTT broker on one LM and use the same approach as mentioned in our knowledge base but with a local server.
Threads: 48
You need to assign this tag to objects first.
Threads: 31
Go to LogicMachine object tab and click on it and add TAG. You can also use filter and Mass edit to do many at once.
