Threads: 0
he Zigbee gateway does not work after a network outage and shows an error message:
lua: /tmp/tmp.mtkFYYoRG4/files/store/daemon/zigbee/lib/ctx.lua:191: ...tmp.mtkFYYoRG4/files/store/daemon/zigbee/zigbee/core.lua:979: ZB: could not start coordinator
stack traceback:
[C]: in function 'error'
/tmp/tmp.mtkFYYoRG4/files/store/daemon/zigbee/lib/ctx.lua:191: in function 'task_resume'
/tmp/tmp.mtkFYYoRG4/files/store/daemon/zigbee/lib/ctx.lua:204: in function 'callback'
/tmp/tmp.mtkFYYoRG4/files/store/daemon/zigbee/lib/ctx.lua:158: in function 'task_timer_run'
/tmp/tmp.mtkFYYoRG4/files/store/daemon/zigbee/lib/ctx.lua:39: in function 'run'
/tmp/tmp.mtkFYYoRG4/files/store/daemon/zigbee/app.lua:493: in main chunk
[C]: at 0x00014afc
Threads: 30
Try rebooting LM. If this will not help try powering down all zigbee routers(all mains powered devices) and reboot again.
What are the LEDs says?
Threads: 30
Did you perform the actions I described above?
Threads: 30
Double check the cables but if still not ok contact us via email for replacement.
Threads: 18
Do other people also experience problems and instable operation with the zigbee rs232 gateway the last couple of months?
More specific, showing a red dot in the zigbee app instead of the green dot - button 'network state: closed'
I experienced this 3 or 4 times now over the past couple of months and today again.
A reboot of the logicmachine doesn't help, only disconnecting the power input of the rs232 zigbee gateway and a logicmachine reboot solves the problem.
My first post in this thread about this dates from 17.12.2025, before that I never had any problems.
Apparently Andy2010 also experienced a similar problem reading his post from 20.12.2025
Apart from this I now have an enocean TMC310 usb gateway which doesn't show up anymore in the logicmachine. I first thought it was the enocean TMC310 usb which was broken but I tested it on my pc with dolphinview advanced and there it is detected and recieves telegrams from the other enocean devices, ensuring me there is nothing wrong with the enocean TMC310 usb device.
In this case, neither restarting the logic machine nor performing a rescan or refresh helps, making it inoperable for now.
Something to look into I guess.
Thanks in advance!
Threads: 48
What is your ZigBee gateway hardware version (check the sticker on the side)? Post what you have in the ZigBee app logs.
Threads: 48
You have older HW v1.1 which LM cannot reset if the gateway does not respond. Contact us via e-mail for replacement.
Threads: 48
See my post above, yours is also HW v1.1.
When replacing the gateway make sure to turn off all powered ZigBee devices beforehand. Otherwise network won't be created. Some devices might need to be paired again.
Threads: 30
Only mains powered devices, not battery
Threads: 48
Keep the ZigBee app open when replacing the gateway. You will get an error message if the network cannot be formed when the gateway starts.
