Visu bugs
#61
(21.01.2026, 07:56)admin Wrote: Is your local Visu app up to date?
20251121
Send your project backup to PM
What browser and OS do you use? Your backup works fine for me.
@Fahd, you need to adjust your grid CSS. Don't use align-items: center; and use pixels for sizing. Otherwise the grid will shift when Visu is scaled automatically on smaller screens.
HW: LM5 Lite (i.MX6)
SW: 20251204
I think I may have found a bug in the new LogicMachine Visu interface and I would like to understand if others can reproduce it.
Configuration:
  • I created a 14-byte ASCII String object and bound it to the “Text Input” widget in Visu.
  • I created a 4-byte Unsigned Integer object and bound it to the “Numeric Input” widget in Visu.
Behavior:
In the local Visu Admin section (View Mode) everything works correctly.
In the local Visu on the LogicMachine everything works correctly.
When accessing the Visu through https://remote.logicmachine.net/ (both from a PC browser and from mobile devices using the LM Home app), the following issues occur:
Issues observed:
-- Numeric Input problem
The numeric input wraps at 255 and then starts again from 0.
Examples:
Writing 256 results in 0
257 → 1
258 → 2
3256 → 184
This looks like an 8-bit overflow behavior, even though the object is a 4-byte unsigned integer.
-- Text Input problem
The text input value is not displayed at all.
I also noticed a JavaScript conversion error in the browser console:
index-RjiBgizA.js.gz:678 Uncaught TypeError: t.replace is not a function
    at hQ.updateValue (index-RjiBgizA.js.gz:678:5365)
    at onShow (index-RjiBgizA.js.gz:678:5942)
    at d (index-RjiBgizA.js.gz:693:267267)
    at index-RjiBgizA.js.gz:693:267343
Has anyone experienced the same behavior or can confirm if this is a known issue with remote Visu / LM Home?
Send me your project backup to PM as I cannot recreate this issue.
Just make sure to sync cloud after each change, do it again just in case.
Thanks for the backup. I synced it with my own account and all works fine for me. On one of the string objects you had different object for status. If you use status only the status will be displayed so make sure it actually works.
Probably you just need another sync.
    I have 3 LM's. On one of them, the option "Sync project to LM Cloud", is not available.
Any idea on what might be wrong?
Check LM cloud app for more info
(Yesterday, 10:37)Daniel Wrote: Check LM cloud app for more info
Got it. Thanks.
