LAN IP to KNX object - SOLVED
How can I read the IP LAN assigned by DHCP server to one KNX object ? So I can know the IP address of the LM in DHCP mode (similar at pubblic address IP for WAN ).
Otherwise, is there a way to know the IP address of the LM in DCHP mode without internet connection ?
Thanks,
Alberto
require('json')
require('socket.http')
ip = io.readproc('if-json')
ip = json.decode(ip)
log("IP address: " ..ip.eth0.inetaddr)
KNX Advanced Partner + Tutor
For public IP:
require('json')
socket.http.TIMEOUT = 5
local data = socket.http.request('http://api.ipify.org')
if not data then
  return
  log('No response getting IP')
--log(data)
if data == 'Bad Gateway' then
ip_old = storage.get('ip_old')
if ip_old == nil then
  storage.set('ip_old', data)
If using DHCP you should bind LM MAC to a certain IP on your router (static DHCP entry). Otherwise LM IP can change randomly.
