fade time function
Dear reader,
Is there a fade time function?
I want to use a timer to start the fade time (adjustable from 30 to 60 minutes using a KNX group address). The lights then take the set time to dim from 100% to 0%.
and vice versa from 0 to 100% with a different time clock
Thank you in advance.
This should be defined in your dimmer.
(Yesterday, 11:07)Daniel Wrote: This should be defined in your dimmer.
That's not possible because the switch needs to switch on and off directly. And because of the script, I need a fade time, and I can only set one function on the dimmer
You can make a script which will do it but you will simply have to send several commands over time. It can also be done via scene with delay option in.
