apple Home kit not adding accessory
hi sir
we are having issue with apple home in that when we scan QR code for adding our object or accessory to home it is not adding. Only
 loading so what could be issue with that
Did you press Apply changes after adding your device?
(Yesterday, 08:17)Daniel Wrote: Did you press Apply changes after adding your device?
Yes
What does the logs of the app says?
(Yesterday, 08:21)Daniel Wrote: What does the logs of the app says?
In the app all looks good. On your mobile in homekit app remove Home and try again.
(Yesterday, 08:48)Daniel Wrote: In the app all looks good.  On your mobile in homekit app remove Home and try again.
sir,
I tried Still not adding
what iOS version do you use?
You can also try this:
https://www.reddit.com/r/HomeKit/comment...lly_clear/
(Yesterday, 09:27)Daniel Wrote: what iOS version do you use?
ios 26.2.1
We tested it on same version of iOS and works for us. Try the link I sent you above.
(Yesterday, 11:59)Daniel Wrote: We tested it on same version of iOS and works for us. Try the link I sent you above.
Hii Sir I tried Still It is Not connecting.
