Switch widget with 0 value
Hello
I was migrating a project to the new view, and I have a small problem. I need to set an object representation that is tied to a bit. If the bit is at 0, I shouldn't see anything; if the bit is at 1, I should see a colored rectangle. The problem is that when I use the switch widget with the value at 0, it turns blue as if it were active. It's a read-only object.
What am I doing wrong?
1. Set Additional CSS classes to hide-when-false
2. Add to Custom CSS:
.user-view .hide-when-false[data-value=false] {   display: none; }
This will completely hide the widget in user view when the value is false.
(18.02.2026, 12:15)admin Wrote: 1. Set Additional CSS classes to hide-when-false
ok I add this code in custom CSS, for use this code need to wirte in appearance in additional CSS   hide-when-false  ?
Yes the additinal classes are added in widget apperance on the bottom.
