Threads: 4
hi sir
we are having issue with apple home in that when we scan QR code for adding our object or accessory to home it is not adding. Only
loading so what could be issue with that
Threads: 30
Did you press Apply changes after adding your device?
Threads: 30
What does the logs of the app says?
Threads: 30
In the app all looks good. On your mobile in homekit app remove Home and try again.
Threads: 30
what iOS version do you use?
Threads: 30
Threads: 30
We tested it on same version of iOS and works for us. Try the link I sent you above.
Threads: 48
Can you access LM web interface from your mobile?
