Arylic integration via TCP API
Hi guys,
Arylic is a brand creating audio amplifiers, pre-amplifiers and streamers. It is pretty widely used due to its cost-effective price. It has multiple ways for integration into 3rd party systems, which include:
TCP API:  TCP API – Arylic Audio TCP API Interface
HTTP API:  HTTP API – Arylic Audio HTTP API
We have made a working script for integration via HTTP API - if someone is interested I could post it here. Maybe it would be possible to get an example for integration via TCP API? Some of the newer Arylic devices does not support HTTP API anymore while continuing support for TCP API.
Many thanks in advance!
Here's an example of sending commands:
function encodeuint32(value)   local bytes = {}   for i = 1, 4 do     bytes[ i ] = bit.band(value, 0xFF)     value = bit.rshift(value, 8)   end   return string.char(unpack(bytes)) end function encode(cmd)   if #cmd > 11 then     cmd = cmd .. '&'   end   local csum = 0   for i = 1, #cmd do     csum = csum + cmd:byte(i)   end   return     string.char(0x18, 0x96, 0x18, 0x20) ..     encodeuint32(#cmd) ..     encodeuint32(csum) ..     string.char(0x00):rep(8) ..     cmd end sock = require('socket').tcp() sock:settimeout(5) res, err = sock:connect('192.168.1.1', 8899) if res then   data = encode('MCU+VOL+050')   sock:send(data)   log('send ok') else   log('connection failed', err) end sock:close()
For full integration the response must be parsed. Since the device can only handle a single TCP connection you will need a resident script that handles both sending commands and receiving status message from the device.
Thanks, admin! Works perfectly, as always.
