Hi !
In my environment I had my LM running for over 3 years.
Yesterday, for the first time all data in the database was gone and all objects and scripts are lost.
I can see alert log but there is no other log or error log.
Have you ever experienced this ? How can I avoid it from happening?
(03.10.2025, 08:39)Hadeel Wrote: Hi !
I installed my LM for a small project approximately three months ago.
About one month ago, the LM began rebooting every morning at irregular times, typically between 5:45 and 6:15.
The issue is that yesterday I was able to see valid trend data, but today—after the reboot—the trend history from yesterday is missing, and only constant values are displayed.
I replaced the LM with a new unit, but the behavior remains the same.
Could you please advise on the next steps to resolve this issue?
(04.12.2025, 08:29)Daniel Wrote: You probably running out of memory and this is why LM reboots. Check what could be the reason, System load app may help.
Okay, but if the LM stopped me from creating trends, how would I end up running out of memory?
When I create trends, I don’t get any alert that I’m running out of memory.
(04.12.2025, 09:42)Daniel Wrote: Send me your backup to PM. Use some file storage tool and drop a link.
I also meet the same problem but it happen frequently. Each time, I use the backup file to restore it so I dont really know it happen when the power is lost or not, all database is lost after 1-3 months. I try to replace a new Micro SD card, use the latest firmware but the problem still happen. The next time, I will run those code and send you the log, is it?
res = io.readproc('ls -l /data/dbfail/')
log(res)
log(io.readfile('/data/dbfail/1.log'))
log(io.readfile('/data/dbfail/2.log'))
