Homelynk Admin Password
Hello
I have "inherited" a KNX project with a homelynk server installed.
Unfortunately, the previous integrator is no longer available for the project and the current administrator password is unknown. For the visualization part, a new setup would not be that difficult however he implemented some "magic" logic modules which also are not documentet.
Is there a way to get hold of the admin password without resetting the machine?
Would it be possible to read the current project from the e.g. SD card, reset the system and load the project again into the system?
Thanks for your help
--Thomas
It's not possible to recover the password. But it can be changed if you can access the SD card from Linux.
(12.08.2020, 14:21)admin Wrote: It's not possible to recover the password. But it can be changed if you can access the SD card from Linux.
That sounds very interesting. Yes, I can access the SD Card from Linux.
Could you give me details on how to change it?
Thank you !!
Sent via PM
Can you send me the procedure ?
B.R.
(13.08.2020, 13:39)admin Wrote: Sent via PM
Can you also send me the process?
thx
Thank you !!
Could you please send me the way to do it to?
Thank you in advance!
KR
Stefan
Hi. Can you help me too.  I can access the SD Card from Linux kaly.   Could you give me details on how to change password?
Hello, could you please send me the process?
(13.10.2023, 21:35)nmedalacabeza Wrote: Hello, could you please send me the process?
Hello
I'm also in this situation where the admin password is unknown.
I would be very pleased to get the information about the process to change the password Smile
Hardware factory reset.
Thats the last alternative.
It would be convenient to be able to just change the password, as i dont have any backup of the system and dont want to re-program everything.
I've just received an installation where integrator not longer is active and there isn't admin password. Can you send me procedure to reset admid password please?
