Modbus TCP problem
hello please help. It seams that LM do not initiate any modbus tcp read request to modbus slave device. Tested with modbus Poll all works fine.
Tried firmware upgrade - same issue.
any ideas?Smile
See if you can ping Modbus device IP address from System config > Status > Network utilities.
(Yesterday, 10:39)admin Wrote: See if you can ping Modbus device IP address from System config > Status > Network utilities.
hi tested - 4 packets transmitted, 0 packets received, 100% packet loss. Both, LM and other device i can access via http. Do you have a clue?
what IP settings are on LM and on your Modbus tcp device (IP, Netmask, Gateway)
LM:                   192.168.1.3, 255.255.255.0, 192.168.1.1
Modbus device : 192.168.1.4, 255.255.255.0, 192.168.1.1
Same subnet. Both devices are reachable from my PC, and ping works 100%.
How are both devices connected? Switch or router? Maybe there is a firewall or port isolation is enabled.
