Threads: 160
Good morning
I'm having a problem with an LTE reactor on which I've enabled ZeroTier. The device only responds to pings within its own VLAN. It doesn't respond from outside with the appropriate rules, and it's unreachable. Meanwhile, two Android panels with web browsers respond to pings from both inside and outside. What could it be? The network staff has already checked everything, and everything appears to be configured correctly.
As always, thanks for the information.
Threads: 48
Since you are using LTE, the default gateway comes from the mobile network. Due to this LM cannot reach another VLAN.
You can add a route manually via a script. Ask the network staff for correct destination network parameters and gateway address.
Code: os.execute('route add -net 192.168.10.0/24 gw 192.168.1.1 eth0')
Then add the code to the init script so the route is added automatically after each reboot.
Threads: 160
21.04.2026, 11:30
(This post was last modified: 21.04.2026, 11:31 by Frank68.)
(21.04.2026, 11:03)admin Wrote: Since you are using LTE, the default gateway comes from the mobile network. Due to this LM cannot reach another VLAN.
but work for little time and aftfer not work
os.execute('route add -net 10.255.28.128/27 gw 10.255.28.129 eth0')
the subnet is 255.255.255.224
also I have disable zerotier
Threads: 48
Try temporary disabling LTE and see if it makes any difference.
Threads: 160
(21.04.2026, 11:34)admin Wrote: Try temporary disabling LTE and see if it makes any difference.
now i have no possibility to connect , the rgth procedure for reset to factory for reactor LTE ?
tank's
Threads: 48
Did you reboot LM after disabling LTE?
Hold the reset button for 10 seconds until red LED starts flashing. Then you should be able to access it via 192.168.0.10. Make sure that you connect directly to LM and your PC IP belongs to 192.168.0.x network.
Threads: 160
(21.04.2026, 12:22)admin Wrote: Did you reboot LM after disabling LTE?
nothing the led blink in red baut not possible access to logimachine, i'm connect directly but I have no resposnse for ping
Threads: 48
Post a screenshot of your PC network interface IP settings.
Threads: 160
(21.04.2026, 12:29)admin Wrote: Post a screenshot of your PC network interface IP settings.
i have attached the screen shoot
Threads: 31
no atachments
Threads: 160
(21.04.2026, 12:51)Daniel Wrote: no atachments sorry
Threads: 48
Do you see any LED activity on LM LAN port?
Threads: 160
21.04.2026, 13:01
(This post was last modified: 21.04.2026, 13:03 by Frank68.)
(21.04.2026, 12:57)admin Wrote: Do you see any LED activity on LM LAN port?
yes
but i think not work reset to factory, when i press reset the bottol led go fixed red and afte >10 s start blinking. but not respond on ip fctory.
Threads: 31
For me it always work but if it doesn't then the only option is factory reset. now press once so LM will reboot and then press for 10 sec, till LED will flash RED, release and then press again for 10 sec till LED will start flashing faster.
I hope you have a backup.
Threads: 160
(21.04.2026, 13:10)Daniel Wrote: For me it always work but if it doesn't then the only option is factory reset. now press once so LM will reboot and then press for 10 sec, till LED will flash RED, release and then press again for 10 sec till LED will start flashing faster.
yes I have a backup, when I restart it doesn't restore, I don't get the IP 192.168.0.10
Threads: 31
Did you perform the factory reset as described? Did the LED worked as in description? It is easy to press wrongly. If it still doesn't work then it is your PC network settings or cable.
Threads: 160
Good evening
Tomorrow I'll be back on the system. I'll try setting the route and disabling LTE. The only problem, if it works, is that I should be able to send emails and text messages from the system. Since I don't have internet access on the internal network, I won't be able to use these features. How can I fix this?
Thank you very much.
Threads: 48
What is the LM local IP address? The route that you have posted does not look right. Router address should be an IP address that belongs to the same subnet as LM, but the destination network must be something different.
Alternatively you can add another local IP address:
Code: os.execute('ifconfig eth0:1 192.168.2.2 netmask 255.255.255.0 up')
Threads: 160
24.04.2026, 08:13
(This post was last modified: 24.04.2026, 08:40 by Frank68.)
(24.04.2026, 06:39)admin Wrote: What is the LM local IP address? The route that you have posted does not look right. Router address should be an IP address that belongs to the same subnet as LM, but the destination network must be something different.
Good morning, Daniel
I attach file for current net setting from naetwork staff.
I've now disabled LTE and zero-tier. The device works fine on the VPN and as a programming port. I can send SMS messages, but not emails. Could it be that the emails trying to go out are using the network with the parameters set and the network isn't enabled to send emails?
Now I'll try contacting the network technicians and see how I can resolve the issue. Otherwise, can you offer alternative solutions?
As always, thank you very much.
Threads: 48
LM already belongs to the network that you were trying to add the route to. Route should be added to a network that resides on a different VLAN.
