YABE
Good afternoon,
I have created a VPN through which I access four logic machines:
-192.168.0.11
-192.168.0.12
-192.168.0.13
-192.168.0.14
The VPN IP address on my computer is 10.8.0.3. The four logic machines are configured to deliver data via BACnet IP address, each separately.
I need to connect remotely to the logic machines through the VPN using Yabe to verify that the BACnet connection is working correctly and is of good quality. However, I am unable to access the IP addresses of the logic machines or the objects that each logic machine exports via BACnet IP address.
BACnet device discovery uses broadcast communication which is limited to a single network. It won't work over VPN since your VPN IP belongs to a different network.
Is there a way to remotely check the BACNET IP communication? I don't know if it's through CMD.
You either must be in the same sub-network as LMs (192.168.0.x) or you must use BACnet router (BBMD). There's no other way.
Please stop asking the same question multiple times. You won't get a different answer.
