CANx DALI - setting the default color temperature
I am currently using the CANx DALI gateway to control my lighting.
I have a device that can change the color temperature using DT8, and I want to set this device's color temperature at a specific value at all times (i.e 3000K)
However, every time the power goes off and turns back on again, the color temperature goes back to its default value.
I found this parameter configuration where I can set the power on level. Would it be possible to add a parameter for the color temperature upon power on as well?
Do you have the latest app version installed?
