Threads: 31
You clearly have some loop there and it should not be linked to dali at all. Log the objects also the 32/1/1 and see what is triggering it. In a meantime change the grp.write to grp.checkwrite
Threads: 2
the 32/1/1 is triggered by the visu control. But I verified the event script attached to it from the script window with "run script". In log and error log windows I have nothing. In DALI cockpit-monitor I have the "flood". Also you ca see that the command is sent two times per each iteration. I made a real "installation" for the test. The 32/1/1 group hat the scrip for several luminaries
the script is:
local value = event.getvalue()
grp.checkwrite('1/1/130', value)
grp.checkwrite('1/1/52', value)
grp.checkwrite('1/1/133', value)
grp.checkwrite('1/1/142', value)
grp.checkwrite('1/1/46', value)
grp.checkwrite('1/1/4', value)
grp.checkwrite('1/1/76', value)
grp.checkwrite('1/1/121', value)
DALI log:
DALI16 DAP 5c fe A46 DIRECT ARC POWER 254 (100%) 14:42:52.431 07/24/26
DALI16 DAP 5c fe A46 DIRECT ARC POWER 254 (100%) 14:42:52.465 07/24/26
DALI16 DAP 54 fe A42 DIRECT ARC POWER 254 (100%) 14:42:52.502 07/24/26
DALI16 DAP 1e fe A15 DIRECT ARC POWER 254 (100%) 14:42:52.532 07/24/26
DALI16 DAP 1e fe A15 DIRECT ARC POWER 254 (100%) 14:42:52.569 07/24/26
DALI16 DAP 22 fe A17 DIRECT ARC POWER 254 (100%) 14:42:52.599 07/24/26
DALI16 DAP 02 fe A1 DIRECT ARC POWER 254 (100%) 14:42:52.633 07/24/26
DALI16 DAP 02 fe A1 DIRECT ARC POWER 254 (100%) 14:42:52.667 07/24/26
DALI16 DAP 22 fe A17 DIRECT ARC POWER 254 (100%) 14:42:52.700 07/24/26
DALI16 DAP 30 fe A24 DIRECT ARC POWER 254 (100%) 14:42:52.734 07/24/26
DALI16 DAP 30 fe A24 DIRECT ARC POWER 254 (100%) 14:42:52.768 07/24/26
DALI16 DAP 4e fe A39 DIRECT ARC POWER 254 (100%) 14:42:52.801 07/24/26
DALI16 DAP 4e fe A39 DIRECT ARC POWER 254 (100%) 14:42:52.835 07/24/26
DALI16 DAP 56 fe A43 DIRECT ARC POWER 254 (100%) 14:42:52.868 07/24/26
DALI16 DAP 56 fe A43 DIRECT ARC POWER 254 (100%) 14:42:52.902 07/24/26
DALI16 DAP 54 fe A42 DIRECT ARC POWER 254 (100%) 14:42:52.936 07/24/26
DALI16 DAP 5c fe A46 DIRECT ARC POWER 254 (100%) 14:42:52.969 07/24/26
DALI16 DAP 5c fe A46 DIRECT ARC POWER 254 (100%) 14:42:53.003 07/24/26
DALI16 DAP 54 fe A42 DIRECT ARC POWER 254 (100%) 14:42:53.036 07/24/26
DALI16 DAP 1e fe A15 DIRECT ARC POWER 254 (100%) 14:42:53.070 07/24/26
DALI16 DAP 1e fe A15 DIRECT ARC POWER 254 (100%) 14:42:53.104 07/24/26
DALI16 DAP 22 fe A17 DIRECT ARC POWER 254 (100%) 14:42:53.137 07/24/26
DALI16 DAP 02 fe A1 DIRECT ARC POWER 254 (100%) 14:42:53.171 07/24/26
DALI16 DAP 02 fe A1 DIRECT ARC POWER 254 (100%) 14:42:53.205 07/24/26
DALI16 DAP 22 fe A17 DIRECT ARC POWER 254 (100%) 14:42:53.237 07/24/26
DALI16 DAP 30 fe A24 DIRECT ARC POWER 254 (100%) 14:42:53.270 07/24/26
DALI16 DAP 30 fe A24 DIRECT ARC POWER 254 (100%) 14:42:53.304 07/24/26
DALI16 DAP 4e fe A39 DIRECT ARC POWER 254 (100%) 14:42:53.337 07/24/26
DALI16 DAP 4e fe A39 DIRECT ARC POWER 254 (100%) 14:42:53.371 07/24/26
DALI16 DAP 56 fe A43 DIRECT ARC POWER 254 (100%) 14:42:53.404 07/24/26
DALI16 DAP 56 fe A43 DIRECT ARC POWER 254 (100%) 14:42:53.438 07/24/26
DALI16 DAP 5c fe A46 DIRECT ARC POWER 254 (100%) 14:42:53.472 07/24/26
DALI16 DAP 5c fe A46 DIRECT ARC POWER 254 (100%) 14:42:53.505 07/24/26
Threads: 31
To debug it go to object tab, select log on relevant objects. Trigger the script from visu and drop screenshot from Object logs tab.
Threads: 2
Thank you very much, I found it. It turns out that after any change to a script in the LM5, no matter how small, you must reload the LM Home application on the display. Otherwise, the "flood" occurs.
