Aqara T2 E27 Zigbee support
Hi, does the Aqara LED Bulb T2 E27 work with the LogicMachine Zigbee gateway in Zigbee mode? I could not find it in the supported device list. Does it support on and off, dimming, colour temperature and RGB? If not, can support be added? Thanks.
If it is not on the list then you know the same as we do. If they fallowed zigbee standard then the basic control should work.
Thanks Daniel. Zigbee2MQTT supports this bulb. Could its device definition help add support in LM? What device information or logs would you need from me?
https://www.zigbee2mqtt.io/devices/T2_E27.html
Pair it and test it. Send device information form the app.
