Door lock - DANALOCK?
Hi.
Which door Locks do you guys ingegrate to Your KNX Logic Machine (Wiser) Environment?
I have been looking at the DANALOCK which seems to have some great features I do like. Especially the sensing  function of my cell phone. When the phone is near the door, it unlock/lock  the door automaticly for you. So no keys, no kodes no nothing. Just open the door. Sounds like a very pleasant feature.
This Lock could propably live it's life stand-alone disconnected from my LM/KNX system. It comes With an Danalock app (WHICH ALL NEW DEVICES DO - TOO MANY APPS).  So my thinking is,  to limit amount of apps and logins and keep Things simple for other memers of the house. It would be great to have the basic functions of it Integrated to my KNX/LM system. In example the Remote unlocking door and locking door in LM Logic in case of package deliveries, guests arriving, Logic if fire alarm or similar.
Anyone with Danalock experience? Anyone With Danalock Integrated in the LM/Wiser?
Other Devices which I rather should look into With similar functionallity?
Has anybody tried the Zigbee Danalock v3 variant with LogicMachine? https://danalock.com/products/danalock-v3-smart-lock
I'm afraid of buying it because it is not in the official list of supported Zigbee devices.
Sorry for insisting on it, but we have a 2 plants house project and it is very interesting for our client.
If the device is not at this list https://kb.logicmachine.net/misc/zigbee-devices/ does it mean it will not work? Or does it simply mean that nobody has tried it yet?
We can't say anything without someone testing it first.
(15.01.2024, 08:19)Daniel Wrote: We can't say anything without someone testing it first.
Ok I'm going to buy some devices that are not in the list and I will give you my feedback. Thank you!
Keep in mind that a profile must be added by us. Without it the lock will pair but won't send any status info.
(15.01.2024, 13:30)admin Wrote: Keep in mind that a profile must be added by us. Without it the lock will pair but won't send any status info.
What do you need from my side to add the profile?
Pair the lock and provide a complete report from the info window (in text form, not as a screenshot).
Hello, please add the profile
Manufacturer: Danalock
Model: V3-BTZBE
Device type: End device
Power source: Battery
Receive when idle: No
Endpoint 1
Profile: 260
Input clusters
- Basic (0)
- PowerCfg (1)
- Identify (3)
- Alarms (9)
- PollCtrl (32)
- ClosuresDoorLock (257)
- HaDiagnostic (2821)
- 64767
Output clusters
- Ota (25)
Reported attributes
- lockstate: 1
Hello, did you get this to work? Smile
L.E.
Any news on this one?
I researched it back than, but did not find a easy way to implement Danalock back than. Propably the world has evolved since than and there are now good solutions for both Danalock and other brands. Good luck.....
I can see it in the supported device but this only means we created profile based on provided data. I don't recall any confirmation from the customer side.
I have been testing the Danalock together with LM5 and it is working fine, I can lock and unlock (Door control), read the status if it is locked or unlock (Lock state) and read the battery level.
The Door state I cant se any change on, but I beleve it is related to that the lock dont have any input of the door is open or closed.
I also have an Danapad that I would like to use together with Danalock V3, I now different "smart hub's" have support to set pin code through the Danalock V3.
The pin codes are stored in Danapad, by using something called Appless pairing between the Danalock and Danapad, it is possable to set pin codes through the zigbee protocoll.
Is it possable to add that functionallity? and is it needed to be done with a script?
Here is some infomation on this topic:
Pin code (composite)
Can be set by publishing to zigbee2mqtt/FRIENDLY_NAME/set with payload {"pin_code": {"user": VALUE, "user_type": VALUE, "user_enabled": VALUE, "pin_code": VALUE}} To read (/get) the value publish a message to topic zigbee2mqtt/FRIENDLY_NAME/get with payload {"pin_code": ""}.
user (numeric): User ID to set or clear the pincode for
user_type (enum): Type of user, unrestricted: owner (default), (year|week)_day_schedule: user has ability to open lock based on specific time period, master: user has ability to both program and operate the door lock, non_access: user is recognized by the lock but does not have the ability to open the lock allowed values: unrestricted, year_day_schedule, week_day_schedule, master, non_access
user_enabled (binary): Whether the user is enabled/disabled allowed values: true or false
pin_code (numeric): Pincode to set, set pincode to null to clear
The text is coming from:
https://www.zigbee2mqtt.io/devices/V3-BT...-composite
Adding pin code functionality requires some changes in the app. We will look into this. You will still need a short script to set the pin code.
