Different LM configuration
Hi! I have some LM with last version firmware 20251204, but different configurations
DALI.jpg has (DALI, EnOcean, 1-wire)
noDALI.jpg has not these tabs (DALI, EnOcean, 1-wire)
I don't know where I have to configure it.
thanks
It seems that you installed wrong firmware on it. What LM is it? Check the side label.
First one is:
Second one is:
Maybe I confused when I installed firmware? Because two machines are physically the same.
Can I reinstall the LM5 lite firmware in the first one?
Software will not tell you the truth if you already used wrong firmware, check the side label.
