Threads: 38
21.06.2017, 07:02
(This post was last modified: 21.06.2017, 07:02 by Mirco.)
with the firmware version 1.5.1 for HL I was able to set Visualizzation as default Home Page also with password, now with firmware 2.0.0 I'm not able to do it anymore.. it always open apps..
Is there a way?
Thanks!
Threads: 103
Thank you Morak. It works on LM5 too!
Mirco, You can use the setup from here
https://forum.logicmachine.net/showthrea...ull-screen
instead of a native 3rd application.
Threads: 1
Can you give me an Android app installation package? I want to use it in mainland China, but I can't find it in Android Store.You can send to my mailbox rick.shi@advanceddevices.com.THANKS!
Threads: 35
Threads: 17
i can`t change main page with the script:
dst = '/www/index.html' io.writefile(dst, [[<!DOCTYPE html> <html> <head> <meta http-equiv="refresh" content="0;URL=/scada-vis/"> </head> <body></body> </html>]])
¿ is possible to do this with another script??
Threads: 8
Did you disable “Block unsafe functions in scripts” in the general configuration before executing the script?
io.writefile is otherwise blocked..
