Help
Hi all, please help, I have a script with two conditions and I need the script to start working if the first condition is false and the other true. For example...
Twilight = grp.getvalue("9/1/2")
ObjA = grp.getvalue("9/2/100")
if Twiligt false and ObjA == true then
Where am I making a mistake?
You can do something like this:
if twilight == true or objA == true then
-- do something
or shorter way:
if twilight or objA then
-- do something
to Buuuudzik
I know, but I need to judge both conditions at once so one will be false and the other true...
(09.08.2017, 20:23)kostal.borek Wrote: to Buuuudzik
If I understand right you want doing something when this 2 values will be opposite? If yes below script should be enough:
if twilight ~= objA then
-- do something
(09.08.2017, 18:26)kostal.borek Wrote: Hi all, please help, I have a script with two conditions and I need the script to start working if the first condition is false and the other true. For example...
Hi Kostal,
First make sure that 9/1/2 and 9/2/100 are booleans. Then try this :
Twilight = grp.getvalue('9/1/2')
ObjA = grp.getvalue('9/2/100')
if (Twiligt == false and ObjA == true) then
--do something
Chouaibou.
Hi, apologize to all. I have not noticed errors in my own script. In the first line I wrote Twilight and in the third I wrote Twiligt ...
