Write value to another LM without KNX IP
I have point in my LM (LM-1) which is a 255 byte string type point. When I change value of this point, I want to write to another 255 byte string type point which is located in another LM (LM-2). I cannot use KNX IP futures or something (Because there are same KNX addresses in another LM's)
I need a script which write value to another LM contains IP address of LM and KNX Point address.
Thanks,
You can either setup KNX/IP filteting so only one required group address is passed (which is not used on the bus). Or you can send via HTTP requests: http://openrb.com/docs/remote-new.htm
We cannot use filtering. We already used filtering for another purposes. I would like to try http request. But this http request must be trigger by event script. Can i write this http request line in to event script ?
Yes, by using Luasocket HTTP: http://w3.impa.br/~diego/software/luasoc...ml#request
Hi ,
If you write one script regarding to example written below, it will be better.
Source object : LM4 , 192.168.1.80 , 1/1/1 , value : 'Hello World This is may message'
Destination object : LM4 192.168.1.82 , 3/2/2 (username:remote , password:remote )
Regards
This is very trivial. Next time please try using provided examples in the documentation.
http = require('socket.http') url = require('socket.url') http.TIMEOUT = 5 value = event.getvalue() req = 'http://remote:remote@192.168.1.12/scada-remote?m=json&r=grp&fn=write&alias=3/2/2&value=' http.request(req .. url.escape(value))
It worked for the objects those are not binary.. Thanks a lot. For binary points, true and false values are not send with this method. Do you have any suggestion.
Regards,
Add this below value = event.getvalue()
if type(value) == "boolean" then   value = tostring(value) end
(20.09.2017, 15:25)Erwin van der Zwart Wrote: Thank you.
