For anyone it might help I wanted to share some scripts to control Yamaha R-N301 HiFi Receiver and automate a Public Announcement system using SNOM PA1.
The main objective is to make the necessary settings (input, volume etc) on R-N301 when PA receives a call and return to previous state when the call ends.
I am basically new to scripting so any suggestions are welcome.
I have created the following objects on logic machine
![[Image: MGoq9n0.png]](http://i.imgur.com/MGoq9n0.png)
Using Snom PA1 Action URL feature and Logic Machine remote services to update object 2/6/11 when a call is connected or disconnects.
![[Image: 5yya0fY.png]](http://i.imgur.com/5yya0fY.png)
On Connected : http://remote:remote@192.168.16.10/cgi-b...value=true
On Disconnected: http://remote:remote@192.168.16.10/cgi-b...alue=false
Scripts
1. Yamaha R-N301 control and feedback function
2. Object 2/6/11 event script
Scripts
Basic control and feedback function for Yamaha R-N301 amplifier
Input cmd
Get feedback : GET eg rn301('GET', '<Main_Zone><Basic_Status>GetParam</Basic_Status></Main_Zone>')
Send command : PUT eg rn301('PUT', '<System><Power_Control><Power>Standby</Power></Power_Control></System>')
Input param
Update feedback objects : <Main_Zone><Basic_Status>GetParam</Basic_Status></Main_Zone>
Power on : <System><Power_Control><Power>On</Power></Power_Control></System>
Standby : <System><Power_Control><Power>Standby</Power></Power_Control></System>
Mute On : <Main_Zone><Volume><Mute>On</Mute></Volume></Main_Zone>
Mute Off : <Main_Zone><Volume><Mute>Off</Mute></Volume></Main_Zone>
Volume (0-100) : <Main_Zone><Volume><Lvl><Val>50</Val><Exp>0</Exp><Unit></Unit></Lvl></Volume></Main_Zone>
Input : <Main_Zone><Input><Input_Sel>LINE1</Input_Sel></Input></Main_Zone>
Returns table with status feedback (Result, Rescode, Power, Volume, Mute, Input)
function rn301(cmd, param)
require 'socket.http'
-- Create HTTP post body
local request_body = '<?xml version="1.0" encoding="utf-8"?>' ..
'<YAMAHA_AV cmd="' .. cmd.. '">' ..
(param or '') ..
'</YAMAHA_AV>'
local response_body = { }
local status_tbl = { }
-- Send command to amplifier
local result, code = socket.http.request
url = 'http://192.168.16.22/YamahaRemoteControl/ctrl',
method = 'POST',
headers =
["Content-Type"] = "application/x-www-form-urlencoded",
["Content-Length"] = request_body:len(),
source = ltn12.source.string(request_body),
sink = ltn12.sink.table(response_body),
-- Check responce from amplifier
if result and code==200 then
status_tbl['Result']=result
status_tbl['ResCode']=code
if cmd == 'GET' then
if type(response_body) == "table" then
response_body=table.concat(response_body)
power=string.sub(string.match(response_body,"<Power>%a+</Power>"), 8, -9)
status_tbl['Power']=power
-- Manipulate and update power feedback object
if power=='On' then
grp.write('2/6/51', true)
grp.write('2/6/51', false)
volume=tonumber(string.sub(string.match(response_body,"<Val>%d+</Val>"), 6, -7))
status_tbl['Volume']=volume
-- Update volume feedback object
grp.write('2/6/53', volume)
mute=string.sub(string.match(response_body,"<Mute>%a+</Mute>"), 7, -8)
status_tbl['Mute']=mute
-- Manipulate and update mute feedback object
if mute == 'On' then
grp.write('2/6/52', true)
grp.write('2/6/52', false)
input=string.sub(string.match(response_body,"<Input_Sel>.*</Input_Sel>"), 12, -13)
status_tbl['Input']=input
-- Update input feedback object
grp.write('2/6/54', input)
alert('HTTP Request Error: Response is empty or unknown')
alert('HTTP Request Error: ' .. code)
return status_tbl
value=event.getvalue()
-- Update feedback objects
yamaha=grp.getvalue('2/6/51')
-- 1st case: Call Connected and R-N301 already On
-- Store current power status, input and volume level
-- Set Input to Line1(PA system), Volume to 50 and make sure mute is off
if value and yamaha then
storage.set('yamaha_pwr',yamaha)
prv_volume=grp.getvalue('2/6/53')
storage.set('yamaha_volume',prv_volume)
prv_input=grp.getvalue('2/6/54')
storage.set('yamaha_input',prv_input)
rn301('PUT', '<Main_Zone><Volume><Mute>Off</Mute></Volume></Main_Zone>')
rn301('PUT', '<Main_Zone><Volume><Lvl><Val>50</Val><Exp>0</Exp><Unit></Unit></Lvl></Volume></Main_Zone>')
rn301('PUT', '<Main_Zone><Input><Input_Sel>LINE1</Input_Sel></Input></Main_Zone>')
-- 2nd case: Call Connected and R-N301 already on Standby
-- Power On R-N301, set Input to Line1(PA system), Volume to 50 and make sure mute is off
elseif value and not (yamaha) then
rn301('PUT', '<System><Power_Control><Power>On</Power></Power_Control></System>')
-- 3rd case: Call Disconnects and R-N301 was On before call
-- Set Input, Volume to previous state and make sure Mute is off
elseif (not value) and storage.get('yamaha_pwr',0) then
prv_volume=storage.get('yamaha_volume',30)
prv_input=storage.get('yamaha_input','CD')
rn301('PUT', '<Main_Zone><Volume><Lvl><Val>' .. prv_volume .. '</Val><Exp>0</Exp><Unit></Unit></Lvl></Volume></Main_Zone>')
rn301('PUT', '<Main_Zone><Input><Input_Sel>' .. prv_input .. '</Input_Sel></Input></Main_Zone>')
-- 4th case: Call Disconnects and R-N301 was Off before call
-- Just make sure Mute is off and then power off
