enable disable schedulers
is there a way to enable, disable schedulers and scenes with a script like,
value1 = event.getvalue()
if value1 == true then
  schedulers.disable('name')
  scenes.disable('name')
You can't enable / disable schedulers by script, but you can create some logic and use a internal object for the scheduler and attach script below to it and create a internal object to set the en/disable state.
address_en_disable = '32/0/2'
address_output = '1/1/1'
if event.getvalue() == true and grp.getvalue(address_en_disable) == true then
 grp.write(address_output, true)
 grp.write(address_output, false)
For scenes commands see http://openrb.com/docs/lua.htm#11
There's an unfinished scheduler control library: https://gist.github.com/jsopenrb/e2eb174...2f633205de
Create new user library called scheduler, then use it in your code like this:
scheduler = require('user.scheduler')
scheduler.enable('name')
As Erwin mentioned, scene control is already built-in
