Data from http request - to JSON - to KNX
Hi!
I need a little help with this:
I now got a energy-gateway that can send a JSON-file when requested. The way to do it, is type "http://10.0.0.xxx/output.json" in the web browser.
I then get a file called "output.json" and the string is like this:
{"0015BC001B024257":{"ApplicationHeartbeat":"1","CurrentSummationDelivered":"12812.1","CurrentSummationReceived":"0.0","Tamper":"0","InstantaneousDemand":"4342.0","Battery":"0"}}
The information I need is CurrentSummationDelivered and InstantaneousDemand and the goal is to write this to two KNX groups with 30 seconds intervals.
Any tips where to start? Thanks from a LM5-newbie.  Smile
.json   output.json (Size: 178 bytes / Downloads: 13)
Try something like this:
1234567891011121314151617
require('socket.http') require('json') socket.http.TIMEOUT = 15 data, code = socket.http.request('http://10.0.0.xxx/output.json') if data then  data = json.pdecode(data) end if data then  CurrentSummationDelivered = data['0015BC001B024257'].CurrentSummationDelivered  InstantaneousDemand = data['0015BC001B024257'].InstantaneousDemand  grp.update('1/1/1', tonumber(CurrentSummationDelivered))  grp.update('1/1/2', tonumber(InstantaneousDemand)) end
(21.03.2018, 18:21)Erwin van der Zwart Wrote: Hi,
Something tells me that I am forgetting something? No action on the KNX-bus. (Picture attached)
Add log(data, code) after http request and log(data) at the end of the script, then check Logs tab for results. Do you have objects 4/0/20 and 4/0/21 created in LM?
Here is the solution, thank to you that know who you are. Wink
And thanks for all the help also! Smile
12345678910111213141516171819202122232425
sock = require('socket').tcp() sock:settimeout(5) res, err = sock:connect('10.0.0.112', 80) if res then  sock:send('GET /output.json HTTP/1.1\r\n\r\n')  res = sock:receive('*a')  log(res)  if res then    p, e = res:find('\r\n\r\n', 1, true)    if e then      data = res:sub(e + 1)      data = require('json').pdecode(data)      log(data)    end  end end if data then  CurrentSummationDelivered = data['0015BC001B024257'].CurrentSummationDelivered  InstantaneousDemand = data['0015BC001B024257'].InstantaneousDemand  grp.write('4/0/20', tonumber(CurrentSummationDelivered))  grp.write('4/0/21', tonumber(InstantaneousDemand)) end
