	Threads: 2
		12.02.2018, 08:15
(This post was last modified: 12.02.2018, 10:32 by Hippolyte.)
		Hi everyone,
A lot of questions lately    but this one may be tricky.
We have to update a script on 300 LMs, please tell me there is a simple way to do this remotely … The script name is the same on every LM.
I know there is no API for this but maybe you have another technical solution in your head !
Thank you very much for your help.
Hippolyte
	Threads: 45
		You can create a custom .lp file that will handle this, to which you must pass name and script get/post variables. Like this: http://LM_IP/user/update.lp?name=test&script=log(event)
For better security you should add some extra password/variable check to this file.
 Code: <?
 name = getvar('name')
 scriptdata = getvar('script')
 if name and scriptdata then
 item = script.get(name)
 if item then
 item.script = scriptdata
 db:update('scripting', { script = scriptdata }, { id = item.id })
 -- save script data to file
 script.save(item, true)
 -- reload script/group monitor
 script.reloadsingle(item)
 print('update ok')
 print('script not found')
 print('invalid arguments')
	Threads: 2
		13.02.2018, 11:55
(This post was last modified: 13.02.2018, 11:56 by Hippolyte.)
		Wow thank you for your responsiveness ! I'll try this soon and keep you inform.Thx !
	Threads: 2
		Hello, I have an error when doing exactly what you wrote.
 "Error in /www/user/update2.lp at line 5: attempt to index global 'script' (a nil value)"
 Can you help me with that please ?
	Threads: 45
		Add require('apps') to the next line after <?
	Threads: 2
		That's what I did. Now I have "Error in /www/user/update.lp at line 10: '=' expected near '  if'"
	Threads: 45
		Post your full code, you probably modified something by accident
	Threads: 2
		Code: <?require('apps')
 if item then
 print('update ok')
Here it is
	Threads: 161
		Try log variables and check in LM logs what could be the source of problem, like below: Code: You can try to log it like this:
 require('apps')
 log(1, name, scriptdata)
 log(2, item)
 if item then
 log(3, item.script)
 res = db:update('scripting', { script = scriptdata }, { id = item.id })
 log(4, res)
 log(5, 'After script.save')
 print('update ok')
Done is better than perfect
	Threads: 7
		21.03.2018, 12:23
(This post was last modified: 21.03.2018, 12:24 by Erwin van der Zwart.)
 If this is your full sample then you miss ?> at the end ..
	Threads: 45
		Code is fine, ending ?> is optional. Double check .lp file contents on your device.
	Threads: 2
		21.03.2018, 16:38
(This post was last modified: 21.03.2018, 16:44 by Hippolyte.)
		 (21.03.2018, 12:41)admin Wrote:  Code is fine, ending ?> is optional. Double check .lp file contents on your device.
@admin, I literally copy paste the code of my update.lp file on my device.
Are you sure for the http://LM_IP/user/update.lp?name=test&script=log(event)  ?
@Erwin I did add the ?> yet nothing, as admin said it might be optional
@buuuudzik I tried your test and still -> Error in /www/user/update2.lp at line 11: '=' expected near '  log'
I wonder if this is not an issue about the copy paste from this website to the update.lp file. Like invisible caracters coming in the code ...
	Threads: 45
		You probably have a non breaking space there, either use another code editor or remove all leading spaces from the code.
	Threads: 2
		 (21.03.2018, 17:14)admin Wrote:  You probably have a non breaking space there, either use another code editor or remove all leading spaces from the code.
Whether I put it perfectly like this
 if item then
 print('update ok')
Or this
 if item then
 print('update ok')
I still have "Error in /www/user/update.lp at line 11: '=' expected near 'script'"
when I type http://192.168.1.230/user/update.lp?name...log(event)  in Chrome
	Threads: 161
		22.03.2018, 10:19
(This post was last modified: 22.03.2018, 10:59 by buuuudzik.)
		What you have in "Logs" on Logic Machine when you run this code: Code: <?require('apps')
 log(name, scriptdata) -- THIS CODE LOGS VARIABLES IN LM LOGS
 if item then
 print('update ok')
	Threads: 45
		Line 11 is missing comment: Code: -- reload script/group monitor
	Threads: 2
		23.03.2018, 14:28
(This post was last modified: 23.03.2018, 14:47 by Hippolyte.)
		 (22.03.2018, 10:45)admin Wrote:  Line 11 is missing comment:
    I feel so bad ! Sorry for wasting your time and thank you very much all.
It works great !
One last quick question : how do you do a return carriage (new line) ?
	Threads: 2
		Hello, once again thank you for your help.
So it is working really great. Yet I still have this return carriage issue. If I use the http://LM_IP/user/update.lp?name=test&sc...inesscript  then the script is written on only one line when I open it on the LM, do you think there is a way to keep the indentation ?
This is for upgrading script on 500 LMs at the same time
	Threads: 45
		You need to use POST request, because GET query string is limited to a certain number of characters
	Threads: 5
		there is anyway to create the script first? i mean create a script from another script.
 If its posible how i make the diferent scripts types?
 thanks
