Send email with objects file from LM
i have been seeing the next link that explain how to send a email when a KNX object change its value : http://openrb.com/example-sending-email-...desyntax_1
But i have to do a kind of historical to save the value of certain objects every hour, not just one.
So i saw this other link: http://openrb.com/example-export-last-ho...-from-lm2/
The problem here is that i dont need to export CSV file to another FTP Server, i have to generate a email with this file.
Is it possible to do this?
See this thread: https://forum.logicmachine.net/showthread.php?tid=394
if #buffer > 1 then   data = table.concat(buffer, '\r\n')      -- send file as report.csv with text/csv mime type   res, err = mailattach('someone@example.com', 'Report for 2016', 'CSV file attached', 'report.csv', data, 'text/csv')   log(res, err) end
Thanks, but i have not succeeded. So i have started with something simpler to see my error.
I'm trying to send email on KNX group-adress change using this link: http://openrb.com/example-sending-email-from-lm2/
but i don't receive anything. My version is 2.1.1 and i'm using a gmail account with permissions activated.
What's going on??
Log what mail function returns. Also, you should not use mail function from that example, it's outdated.
res, err = mail('test@test.com', 'Alert', 'KNX object 1/2/2 value is: ' .. tostring(value)) log(res, err)
(06.06.2018, 09:35)admin Wrote: Log what mail function returns. Also, you should not use mail function from that example, it's outdated.
Mail function returns this:
* arg: 1
 * nil
* arg: 2
 * string: Try again
You write the example is outdated. Which is the newest, i am having some problem sending emails. Could be my settings are incorrect.. I have tried using my office 365 account, when the new 2 step verification to gmail stops me from completing the allow third party apps..
For gmail with 2-step verification you can generate a separate password for sending e-mails from LM: https://security.google.com/settings/sec...ppasswords
Latest mail function:
-- send an e-mail function mail(to, subject, message)   -- make sure these settings are correct   local settings = {     -- "from" field, only e-mail must be specified here     from = 'example@gmail.com',     -- smtp username     user = 'example@gmail.com',     -- smtp password     password = 'mypassword',     -- smtp server     server = 'smtp.gmail.com',     -- smtp server port     port = 465,     -- enable tls, required for gmail smtp     secure = 'tlsv1_2',   }   local smtp = require('socket.smtp')   if type(to) ~= 'table' then     to = { to }   end   for index, email in ipairs(to) do     to[ index ] = '<' .. tostring(email) .. '>'   end   -- fixup from field   local from = '<' .. tostring(settings.from) .. '>'   -- message headers and body   settings.source = smtp.message({     headers = {       to = table.concat(to, ', '),       subject = subject,       ['From'] = from,       ['Content-type'] = 'text/html; charset=utf-8',     },     body = message   })   settings.from = from   settings.rcpt = to   return smtp.send(settings) end
I tried using this:
Then i received this by email:
KNX object 2/4/2 value is: nil so i need to put something more in the script i guess.
But i found and other post by Daniel. So i downloaded the user.FB_Email for the FBEditor. Installed it. Put the script you posted over here in the common functions and tried out the FBEditor. This only returns:
FB Resident (sleep 60) 15.06.2018 14:04:21
* arg: 1
* nil
* arg: 2
* string: 535-5.7.8 Username and Password not accepted. Learn more at
535 5.7.8 https://support.google.com/mail/?p=BadCredentials y13-v6sm1476447lfk.37 - gsmtp
I only wonder why one script can delivere the email and the other one cant. When i thought they both relied one the common Function to work.
Total newbie to this with scripting.
FB does not use mail from common functions, it comes as a separate user library
Exactly, you have to edit the FB_Email library and put your email setting there.
(15.06.2018, 12:30)Daniel. Wrote: Exactly, you have to edit the FB_Email library and put your email setting there.
I found it. And now its working. Thanks for help.
Is it possible to add in name of CSV-file the date in yymmdd -format?
Gr.
Geert
os.date("%F",d) this will give you date in such format 2020-03-06
PS. Please create new thread when you can't find relevant to your question.
