The problem here is that i dont need to export CSV file to another FTP Server, i have to generate a email with this file.
Is it possible to do this?
Thanks, but i have not succeeded. So i have started with something simpler to see my error.
I'm trying to send email on KNX group-adress change using this link: http://openrb.com/example-sending-email-from-lm2/
but i don't receive anything. My version is 2.1.1 and i'm using a gmail account with permissions activated.
What's going on??
(06.06.2018, 09:35)admin Wrote: Log what mail function returns. Also, you should not use mail function from that example, it's outdated.
res, err = mail('test@test.com', 'Alert', 'KNX object 1/2/2 value is: ' .. tostring(value))
log(res, err)
You write the example is outdated. Which is the newest, i am having some problem sending emails. Could be my settings are incorrect.. I have tried using my office 365 account, when the new 2 step verification to gmail stops me from completing the allow third party apps..
Then i received this by email:
KNX object 2/4/2 value is: nil so i need to put something more in the script i guess.
But i found and other post by Daniel. So i downloaded the user.FB_Email for the FBEditor. Installed it. Put the script you posted over here in the common functions and tried out the FBEditor. This only returns:
FB Resident (sleep 60) 15.06.2018 14:04:21
* arg: 1
* nil
* arg: 2
* string: 535-5.7.8 Username and Password not accepted. Learn more at
535 5.7.8 https://support.google.com/mail/?p=BadCredentials y13-v6sm1476447lfk.37 - gsmtp
I only wonder why one script can delivere the email and the other one cant. When i thought they both relied one the common Function to work.
