I'm trying to connect via Modbus RTU with Siemens Sentron 3100 and the energy value is defined as a Double, how can I define it into LM json archive, thank you very much.
Hi, double support can be added to modbus plugin. I can provide packages if you are willing to test this. Which firmware and hardware versions are you using?
(31.07.2018, 06:58)admin Wrote: Hi, double support can be added to modbus plugin. I can provide packages if you are willing to test this. Which firmware and hardware versions are you using?
I have a LM5Lp and the last firmware version (20170927). Thx
I have another doubt, I have modbus variables that are int32 variables of temperature or power values multiplied by 10, I have tried to use the option to adjust these values in the Modbus definition using 0.1 but I do not know what type of data I have to use in KNX to represent a 32-bit float value. The only option that I have found was to create a new variable and make an intermediate script that divides me by 10 the value read from Modbus. Thank you very much. a greeting
This is old post but I need to help about same issue. I can use double point in profile like below for double points and I selected 8 byte in objects to link this point but the value is getting too big.
