21.08.2018, 16:14
Good, I have a logic machine with 20180523 Firmware and although the objects are well mapped and the settings are correct, I can not get the values or the changes of the Modbus registers, but I use a logic machine with a firmware 20170620 if I can obtain the values of the records and show the changes in the part of objects. It should be noted that both have the same type of Modbus configurations and the same profile, but only in the current version does it work for me. On the other hand if I go to the part of the registry errors I get the following image:
Thank you for your cooperation and I will be attentive to your answers.
