Show control inline in PC/Tablet
#21
(28.01.2017, 12:43)Erwin van der Zwart Wrote:
(27.01.2017, 15:33)Mirco Wrote: Erwin can you make an example? Because I don't know how to do that. Big Grin
Hi Mirco,
You can create a HTML file like this and put it in a iframe with this URL "/user/input.html", run this LUA code once to create the file:
1234567891011121314151617181920212223242526272829303132333435363738394041424344454647484950515253545556575859606162636465666768
-- use this path in your iframe: /user/input.html dst = '/www/user/input.html' io.writefile(dst, [[ <!DOCTYPE html"> <head>  <script type="text/javascript" src="/scada/vis/jquery.js.gz"></script>  <style type="text/css">             body {                 background-color: transparent;             }          .stringinput{              width: 240px;             }        .savebtn{              width: 120px;             }  </style> </head> <body>  <table width="100" border="0">    <tr>  <input id="value1" class="stringinput" type="text" maxlength="255" />    </tr>    <tr>        <input id="btnsave1" class="savebtn" type="button"value="Save" />    </tr>  </table>  <table width="100" border="0">    <tr>          <input id="value2" class="stringinput" type="text" maxlength="255" />    </tr>     <tr>  <input id="btnsave2" class="savebtn" type="button"value="Save" />    </tr>  </table> <script> var p = window.parent; var obj1dpt; var obj2dpt; if (p && p.objectStore){    addr1 = p.Scada.encodeGroupAddress('1/2/34');      p.objectStore.addListener(addr1, function(obj, type) {    $("#value1").val(obj.value);    obj1dpt = obj.rawdatatype;  });  addr2 = p.Scada.encodeGroupAddress('1/2/35');      p.objectStore.addListener(addr2, function(obj, type) {    $("#value2").val(obj.value);    obj2dpt = obj.rawdatatype;  });  $("#btnsave1").on("vclick",function(){    var value1 = $('#value1').val();    p.setObjectValue({ address: ('1/2/34') , rawdatatype: obj1dpt }, value1, 'text');  });  $("#btnsave2").on("vclick",function(){    var value2 = $('#value2').val();    p.setObjectValue({ address: ('1/2/35') , rawdatatype: obj2dpt }, value2, 'text');  }); }; </script> </body> </html> ]]) script.disable(_SCRIPTNAME)
Hi Erwin
Very nice function. But I have one question; Is it possible to add a label to the table as well?
I am not experienced with html at all, so I have no idea how to do that...
Trond
...and one more thing; I want to do this for a lot of objects. How do I loop thru a list of objects and make one entry pr object?
Again, I am not experienced in this, so I need help to do these kind of things Wink
What label do you want to add? Object name?
Yes we can do a loop (: I think creating a loop from objects with a certain tag will work best..
I noticed it uses some old commands and i need to update them to latest commands as well..
(03.10.2018, 07:50)Erwin van der Zwart Wrote: Hi,
The object name for sure is a way to go, although they are somewhat technical in the naming. But for the project I am doing right now, the users are very technical, so I do not think they mind.
Altertatively, I could use two lists; one with the objects and one with the label names.
Trond
Hi Erwin
Sorry to nag you, but have you had any chance to have a look at this issue?
For the project I am doing now, I think a loop through tagged objects using object names as label will do just fine.
Trond
Try this:
I used the tag 'String' to select the tagged objects and changed from .html to .lp for support of client side LUA.
-- use this path in your iframe: /user/input.lp dst = '/www/user/input.lp' io.writefile(dst, [[ <!DOCTYPE html"> <head>  <script type="text/javascript" src="/scada/vis/jquery.js.gz"></script>  <script src="/apps/js/localbus.js.gz"></script>  <script src="/scada/vis/busdecode.js.gz"></script>  <style type="text/css">     body {        background-color: transparent;    }    .inputlabel{      display: inline-block;      width: 150px;        max-wid2h: 200px;      margin-left: 10px;    }    .stringinput{        width: 240px;      margin-left: 10px;      margin-top: 5px;    }    .savebtn{        width: 120px;      margin-left: 50px;    }  </style> </head> <body>  <?     require('apps')   ?>  <script>  localbus.init();  var objects = <? json.write(grp.tag('String')) ?>;  function createInput(name, address, id){     var $input = $('<label id="label_' + id + ' " class="inputlabel">' + name + '</label><table width="100" border="0"><tr><input id="input_' + id + '" class="stringinput" type="text" maxlength="255" /></tr><tr><input id="button_' + id + '" class="savebtn" type="button" value="Save" /></tr></table>');     $input.appendTo($("body"));   }    function addevent(address, id){    $("#button_" + id).data("address", address);    $("#button_" + id).data("id", id);    $("#button_" + id).on( "click", function(e) {        localbus.write(address, $("#input_" + $(e.target).data('id')).val());     });    }    for (var i in objects) {    createInput(objects[i].name, objects[i].address, objects[i].id);   }    $(document).ready(function() {    for (var i in objects) {      addevent(objects[i].address, objects[i].id);      $("#input_" + objects[i].id).val(objects[i].value);    }  });    </script> </body> </html> ]]) script.disable(_SCRIPTNAME)
(10.10.2018, 00:17)Erwin van der Zwart Wrote: Hi,
Try this:
Great! Thanks a bunch!
I will test this in a day or two - need to do some other work right now. I will let you know how it plays out.
Trond
Try this:
Hi Erwin
Just tested this now, worked like a charm! Thanks a lot for the support!
Now, only one more question;
I think I will use this script in a lot of projects. And then also for read only objects. Is there a way to set one field as read only? The save button part, I guess I can just leave out in that case, but I may not always want the customer to be able to edit the values.
And one more question;
In future projects, I might need a different sorting order. Is that something that can be added also?
Trond
Yes all can be created, but i'm not the integrator here, i would advice you to read articles at w3schools.com to learn about HTML5, CSS and JS.
I found some spare time (:
Add the text 'read-only' to the comment field of the object to make it read only and this sample sorts the objects by name: (can be disabled by adding // before line 52)
123456789101112131415161718192021222324252627282930313233343536373839404142434445464748495051525354555657585960616263646566676869707172737475767778798081828384858687
-- use this path in your iframe: /user/input.lp dst = '/www/user/input.lp' io.writefile(dst, [[ <!DOCTYPE html"> <head>  <script type="text/javascript" src="/scada/vis/jquery.js.gz"></script>  <script src="/apps/js/localbus.js.gz"></script>  <script src="/scada/vis/busdecode.js.gz"></script>  <style type="text/css">    body {        background-color: transparent;    }    .inputlabel{      display: inline-block;      width: 150px;      max-wid2h: 200px;      margin-left: 10px;    }    .stringinput{      width: 240px;      margin-left: 10px;      margin-top: 5px;    }    .savebtn{      width: 120px;      margin-left: 50px;    }  </style> </head> <body>  <?    require('apps')  ?>  <script>  localbus.init();  var objects = <? json.write(grp.tag('String')) ?>;    function sortbyname(a, b) {     const NameA = a.name.toUpperCase();     const NameB = b.name.toUpperCase();     let comparison = 0;     if (NameA > NameB) {        comparison = 1;     } else if (NameA < NameB) {        comparison = -1;     }     return comparison;  }  objects.sort(sortbyname);  function createInput(name, address, id, comment){     if(comment.includes("read-only") == true){        var $inputreadonly = $('<label id="label_' + id + ' " class="inputlabel">' + name + '</label><table width="100" border="0"><tr><input id="input_' + id + '" class="stringinput" type="text" maxlength="255" disabled/></tr><tr><input id="button_' + id + '" class="savebtn" type="button" value="Save" disabled/></tr></table>');          $inputreadonly.appendTo($("body"));     } else {        var $input = $('<label id="label_' + id + ' " class="inputlabel">' + name + '</label><table width="100" border="0"><tr><input id="input_' + id + '" class="stringinput" type="text" maxlength="255" /></tr><tr><input id="button_' + id + '" class="savebtn" type="button" value="Save" /></tr></table>');        $input.appendTo($("body"));       }  }    function addevent(address, id){    $("#button_" + id).data("address", address);    $("#button_" + id).data("id", id);    $("#button_" + id).on( "click", function(e) {       localbus.write(address, $("#input_" + $(e.target).data('id')).val());    });   }    for (var i in objects) {     createInput(objects[i].name, objects[i].address, objects[i].id, objects[i].comment);  }    $(document).ready(function() {    for (var i in objects) {      addevent(objects[i].address, objects[i].id);      $("#input_" + objects[i].id).val(objects[i].value);    }  });    </script> </body> </html> ]]) script.disable(_SCRIPTNAME)
Tip: Compare the 2 samples to see what is have changed and you learn a bit how all fits together..
(12.10.2018, 18:53)Erwin van der Zwart Wrote: Hi,
Fantastic!
Will test it, and use some time trying to learn this also. I have just managed to learn LUA, so this will be next step.
Trond
Tested today.
Works very well. I will use this for future solutions also, just need to learn how to manipulate the properties of the different fields I need for the different projects.
This is a great start though.
Trond
