KNX physical address check
(28.02.2016, 20:47)rocfusion Wrote: Hi,
You could try changing the KNX address of the Logic Machine ( found in System Configuration \ Network \ KNX Connection ) to an free address on the first line of the KNX bus.
Thanks,
Roger
Thank you. My LM uses last free address (1.1.253) and dont cross with another devices.
I think what root cause is any problem with bus? but in same time from pinged device im receive another telegram.
KNX physical address check - by Peter - 13.10.2015, 11:33
RE: KNX physical address check - by admin - 13.10.2015, 11:53
RE: KNX physical address check - by Peter - 13.10.2015, 12:10
RE: KNX physical address check - by Peter - 15.10.2015, 06:07
RE: KNX physical address check - by gtsamis - 21.01.2016, 23:30
RE: KNX physical address check - by Ruslan - 28.02.2016, 12:45
RE: KNX physical address check - by rocfusion - 28.02.2016, 20:47
RE: KNX physical address check - by Ruslan - 29.02.2016, 05:44
RE: KNX physical address check - by rocfusion - 29.02.2016, 05:54
RE: KNX physical address check - by admin - 02.03.2016, 08:46
RE: KNX physical address check - by Bergman - 04.11.2025, 20:30
RE: KNX physical address check - by admin - 05.11.2025, 08:06
RE: KNX physical address check - by os.sleep - 13.11.2025, 05:56
RE: KNX physical address check - by Bergman - 06.11.2025, 18:48
RE: KNX physical address check - by Daniel - 13.11.2025, 08:49
RE: KNX physical address check - by os.sleep - 13.11.2025, 14:29
