Script not triggering
I have a couple of this exact script running (8). The total number of scripts is around 60, but most are one or two liners, no timers, wait, delay etc.
All of them are working except this one, the script is enabled and the group address is of the correct data type.
What can I do to clear the problem?
System: CPU/IO: 0.52 0.58 0.57, Memory: 10%, KNX/TP:  OK, error log is empty.
--SPV_act='15/5/3'                 -- ovdje salje vrijednost SPV --SPV_dan='SPV_TEST_dan'            -- varijabla u koju se sprema dnevni SPV --SPV_noc='SPV_TEST_noc'             -- varijabla u koju se sprema nocni SPV --Vremenski_enabled_var='Vremenski_TEST_enable' -- da li je vremenski program omogucen --Dan_Noc='SPV_TEST_dan_noc'            -- podatak da li je aktivan dnevni ili nocni SPV value = event.getvalue() SPV_act='1/3/1'                                      -- SPV active value sending SPV_dan='SPV_hodnik_kat1_dan'                        -- SPV day SPV_noc='SPV_hodnik_kat1_noc'                        -- SPV night Vremenski_enabled_var='Vremenski_hodnik_kat1_enable' -- Is time scheduler enabled? Dan_Noc='SPV_hodnik_kat1_dan_noc'                    -- Is day or night SPV selected storage.set(Dan_Noc,value) enable_vremenski = storage.get(Vremenski_enabled_var) if (enable_vremenski == true) then    if (value == true) then      my_data = storage.get(SPV_dan)      grp.write(SPV_act, my_data)    storage.set(Dan_Noc,value)     end  if (value == false) then      my_data = storage.get(SPV_noc)      grp.write(SPV_act, my_data)        storage.set(Dan_Noc,value)     end end if (enable_vremenski == false) then  my_data = storage.get(SPV_dan)  grp.write(SPV_act, my_data) end
Script not triggering - by zoltan - 29.02.2016, 08:52
RE: Script not triggering - by admin - 29.02.2016, 09:29
RE: Script not triggering - by zoltan - 29.02.2016, 10:38
