Resident script pump circulation
#49
You can try something like this for all zones. Firstly you could only switch off older scripts and check if this would work same as older but for all zones and in only one script. Maybe when you define your zones in same place you found something.
------------------------------------------------------ -- DEFINE GLOBAL VARIABLES AND ZONES------------------ ------------------------------------------------------ seasonGA = '2/0/100' zones = {     {         summer = 'pompa_circolazione_giorno_estate',         winter = 'pompa_circolazione_giorno_inverno',         pump = '2/0/1',         offset = 60,         minimum = 30     } } ------------------------------------------------------ -- DONT CHANGE NOTHING BELOW-------------------------- ------------------------------------------------------ season = grp.getvalue(seasonGA) nextCalculationAfter = 30 -- it will be changed by first zone function calcOutOfTheSeason(tag)     local opened = false     local firstTimestamp = 0     local valves = grp.tag(tag)          for v = 1, #valves, 1 do         local valve = valves[v]                  if valve.value then             opened = true             if firstTimestamp > 0 then                 if firstTimestamp > valve.updatetime then firstTimestamp = valve.updatetime end             else                 firstTimestamp = valve.updatetime             end         end     end          return opened, firstTimestamp end function calcDuringTheSeason(tag)     local opened = false     local firstTimestamp = 0     local valves = grp.tag(tag)          valves = grp.tag(tag)     for v = 1, #valves, 1 do       valve = valves[v]              if valve.value then         opened = true         if firstTimestamp > 0 then           if firstTimestamp > valve.updatetime then firstTimestamp = valve.updatetime end         else           firstTimestamp = valve.updatetime         end       end     end          return opened, firstTimestamp end for z, zone in ipairs(zones) do     local summerTag = zone.summer     local winterTag = zone.winter     local pumpGA = zone.pump     local openingValveTime = zone.offset     local minInterval = zone.minimum          -- CALCULATE SINGLE          local opened, firstTimestamp = false, 0          -- Calc valve state and firsttimestamp for update     if season then         opened, firstTimestamp = calcDuringTheSeason(winterTag)     else         opened, firstTimestamp = calcOutOfTheSeason(summerTag)     end               -- Find nextZoneCalculationAfter for current zone     local nextZoneCalculationAfter = 0          if opened then         local fullyOpened = os.microtime() - firstTimestamp >= openingValveTime                  if fullyOpened then             grp.checkwrite(pumpGA, true)             nextZoneCalculationAfter = minInterval         else             grp.checkwrite(pumpGA, false)             nextZoneCalculationAfter = openingValveTime + 1 - (os.microtime() - firstTimestamp) -- run a little after possible change         end     else         grp.checkwrite(pumpGA, false)         nextZoneCalculationAfter = openingValveTime + 1     end          -- Update nextCalculationAfter (global)     if z == 1 or nextCalculationAfter < nextZoneCalculationAfter then         nextCalculationAfter = nextZoneCalculationAfter     end end -- log('Next calculation after: ' .. nextCalculationAfter .. 's.') if nextCalculationAfter and nextCalculationAfter > 5 then     os.sleep(nextCalculationAfter) else     os.sleep(30) end
Done is better than perfect
RE: Resident script pump circulation - by buuuudzik - 24.10.2018, 20:08
