28.10.2018, 15:22
Look in System config -> Status -> System logs. If you didn' replace SD card then still you should have such errors likeĀ "mmcblk*..*: (.*error*..*)" but if you've changed SD card then probably you don't have such errors because they are on old SD card. But to be sure if this script is good for your LM version you have to compare above pattern with errors in you System logs, because this is how I've created this script.
When you have such error do the picture of logs, alerts, errors, System logs, because then it is helpful for others and also for helpers how to really solve the problem or create monitoring for it, and not only replace the SD card when it breaks in unknown circumstances and after unknown period of time and unknown manufacturer.
Done is better than perfect
