Resident script pump circulation
#59
(27.10.2018, 14:44)buuuudzik Wrote: Here updated version (there was a lack of "." after tablename):
------------------------------------------------------ -- DEFINE GLOBAL VARIABLES AND ZONES------------------ ------------------------------------------------------ seasonGA = '2/0/100' logging = true zones = {     {         summer = 'pompa_circolazione_giorno_estate',         winter = 'pompa_circolazione_giorno_inverno',         pump = '2/0/1',         offset = 60,         minimum = 30     } } ------------------------------------------------------ -- DONT CHANGE NOTHING BELOW-------------------------- ------------------------------------------------------ season = grp.getvalue(seasonGA) nextCalculationAfter = 30 -- it will be changed by first zone if logging then logs = {season = season} end -- #TO DELETE function calcOutOfTheSeason(tag)     local opened = false     local firstTimestamp = 0     local valves = grp.tag(tag)          if logging then logs.zones[#logs.zones].valvesInWinter = {} end -- #TO DELETE          for v = 1, #valves, 1 do         local valve = valves[v]                  if valve.value then             opened = true             if firstTimestamp > 0 then                 if firstTimestamp > valve.updatetime then firstTimestamp = valve.updatetime end             else                 firstTimestamp = valve.updatetime             end         end                  if logging then logs.zones[#logs.zones].valvesInWinter[v] = {name = valve.name, value = valve.value, tags = valve.tags, opened = opened, firstTimestamp = firstTimestamp} end -- #TO DELETE     end          return opened, firstTimestamp end function calcDuringTheSeason(tag)     local opened = false     local firstTimestamp = 0     local valves = grp.tag(tag)          if logging then logs.zones[#logs.zones].valvesInSummer = {} end -- #TO DELETE          valves = grp.tag(tag)     for v = 1, #valves, 1 do       valve = valves[v]              if valve.value then         opened = true         if firstTimestamp > 0 then           if firstTimestamp > valve.updatetime then firstTimestamp = valve.updatetime end         else           firstTimestamp = valve.updatetime         end       end              if logging then logs.zones[#logs.zones].valvesInSummer[v] = {name = valve.name, value = valve.value, tags = valve.tags, opened = opened, firstTimestamp = firstTimestamp} end -- #TO DELETE     end          return opened, firstTimestamp end if logging then     logs.season = season     logs.zones = {} end -- #TO DELETE for z, zone in ipairs(zones) do     local summerTag = zone.summer     local winterTag = zone.winter     local pumpGA = zone.pump     local openingValveTime = zone.offset     local minInterval = zone.minimum          if logging then         logs.zones[z] = {             settings = {                 summerTag = summerTag,                 winterTag = winterTag,                 pumpGA = pumpGA,                 pumpBeforeCmd = grp.getvalue(pumpGA),                 openingValveTime = openingValveTime,                 minInterval = minInterval             }         }     end -- #TO DELETE          -- CALCULATE SINGLE          local opened, firstTimestamp = false, 0          -- Calc valve state and firsttimestamp for update     if season then         opened, firstTimestamp = calcDuringTheSeason(winterTag)     else         opened, firstTimestamp = calcOutOfTheSeason(summerTag)     end          if logging then         logs.zones[z].opened = opened         logs.zones[z].firstTimestamp = firstTimestamp     end -- # TO DELETE          -- Find nextZoneCalculationAfter for current zone     local nextZoneCalculationAfter = 0          if logging then         local pump = grp.find(pumpGA)         local pumpState = { name = pump.name, value = pump.value, lastupdate = os.time() - pump.updatetime }         logs.zones[z].pumpState = {before = pumpState}     end          if opened then         local fullyOpened = os.microtime() - firstTimestamp >= openingValveTime                  if fullyOpened then             grp.write(pumpGA, true)             nextZoneCalculationAfter = minInterval             if logging then logs.zones[z].info = 'Turn on pump because valve is fully opened. Next calculation after ' .. nextZoneCalculationAfter .. 's.' end -- # TO DELETE         else             grp.write(pumpGA, false)             nextZoneCalculationAfter = openingValveTime + 1 - (os.microtime() - firstTimestamp) -- run a little after possible change             if logging then logs.zones[z].info = "Turn off pump because valve isn't yet fully opened. Next calculation after " .. nextZoneCalculationAfter .. 's.' end -- # TO DELETE         end     else         grp.write(pumpGA, false)         nextZoneCalculationAfter = openingValveTime + 1         if logging then logs.zones[z].info = 'Turn off pump because valve is closed. Next calculation after ' .. nextZoneCalculationAfter .. 's.' end -- # TO DELETE     end          if logging then         local pump = grp.find(pumpGA)         local pumpState = { name = pump.name, value = pump.value, lastupdate = os.time() - pump.updatetime }         logs.zones[z].pumpState.after = pumpState     end          -- Update nextCalculationAfter (global)     if z == 1 or nextCalculationAfter < nextZoneCalculationAfter then         nextCalculationAfter = nextZoneCalculationAfter         if logging then logs.zones[z].info = logs.zones[z].info .. ' Variable nextCalculationAfter was changed to ' .. nextZoneCalculationAfter .. '.' end -- # TO DELETE     end end -- log('Next calculation after: ' .. nextCalculationAfter .. 's.') if nextCalculationAfter and nextCalculationAfter > 5 then     if logging then         logs.sleepDescription = 'Calculated ' .. nextCalculationAfter .. 's'         log(logs)     end -- # TO DELETE     os.sleep(nextCalculationAfter) else     if logging then         logs.sleepDescription = 'Default ' .. nextCalculationAfter .. 's (calculated value is 0 or other equal to false)'         log(logs)     end -- # TO DELETE     os.sleep(30) end
Unfortunately not working.
Here below log:
Circolazione mansarda 29.10.2018 17:10:50
* table:
[zones]
 * table:
  [1]
   * table:
    [info]
     * string: Turn off pump because valve is closed. Next calculation after 61s. Variable nextCalculationAfter was changed to 61.
    [settings]
     * table:
      [pumpGA]
       * string: 2/0/2
      [summerTag]
       * string: summer_pump
      [pumpBeforeCmd]
       * bool: false
      [winterTag]
       * string: winter_pump
      [minInterval]
       * number: 30
      [openingValveTime]
       * number: 60
    [pumpState]
     * table:
      [after]
       * table:
        [lastupdate]
         * number: 0
        [name]
         * string: Pompa Circolazione Mansarda
        [value]
         * bool: false
      [before]
       * table:
        [lastupdate]
         * number: 60
        [name]
        [value]
         * bool: false
    [firstTimestamp]
     * number: 0
    [valvesInSummer]
     * table:
      [1]
       * table:
        [value]
         * bool: false
        [firstTimestamp]
         * number: 0
        [name]
         * string: T7 FB Heating floor attic valve
        [opened]
         * bool: false
    [opened]
     * bool: false
[sleepDescription]
 * string: Calculated 61s
[season]
 * bool: true
[size=undefined]
Circolazione mansarda 29.10.2018 17:11:51
* table:
[zones]
 * table:
  [1]
   * table:
    [info]
     * string: Turn off pump because valve isn't yet fully opened. Next calculation after 43s. Variable nextCalculationAfter was changed to 43.
    [settings]
     * table:
      [pumpGA]
       * string: 2/0/2
      [summerTag]
      [pumpBeforeCmd]
       * bool: false
      [winterTag]
      [minInterval]
       * number: 30
      [openingValveTime]
       * number: 60
    [pumpState]
     * table:
      [after]
       * table:
        [lastupdate]
         * number: 0
        [name]
        [value]
         * bool: false
      [before]
       * table:
        [lastupdate]
         * number: 61
        [name]
        [value]
         * bool: false
    [firstTimestamp]
     * number: 1540829493
    [valvesInSummer]
     * table:
      [1]
       * table:
        [value]
         * bool: true
        [firstTimestamp]
        [name]
        [opened]
         * bool: true
    [opened]
     * bool: true
[sleepDescription]
 * string: Calculated 43s
[season]
 * bool: true
[/size]
[size=undefined]
Circolazione mansarda 29.10.2018 17:12:34
* table:
[zones]
 * table:
  [1]
   * table:
    [info]
     * string: Turn off pump because valve isn't yet fully opened. Next calculation after 59s. Variable nextCalculationAfter was changed to 59.
    [settings]
     * table:
      [pumpGA]
       * string: 2/0/2
      [summerTag]
      [pumpBeforeCmd]
       * bool: false
      [winterTag]
      [minInterval]
       * number: 30
      [openingValveTime]
       * number: 60
    [pumpState]
     * table:
      [after]
       * table:
        [lastupdate]
         * number: 0
        [name]
        [value]
         * bool: false
      [before]
       * table:
        [lastupdate]
         * number: 43
        [name]
        [value]
         * bool: false
    [firstTimestamp]
     * number: 1540829552
    [valvesInSummer]
     * table:
      [1]
       * table:
        [value]
         * bool: true
        [firstTimestamp]
        [name]
        [opened]
         * bool: true
    [opened]
     * bool: true
[sleepDescription]
 * string: Calculated 59s
[season]
 * bool: true
[/size]
[size=undefined]
Circolazione mansarda 29.10.2018 17:13:33
* table:
[zones]
 * table:
  [1]
   * table:
    [info]
     * string: Turn off pump because valve isn't yet fully opened. Next calculation after 60s. Variable nextCalculationAfter was changed to 60.
    [settings]
     * table:
      [pumpGA]
       * string: 2/0/2
      [summerTag]
      [pumpBeforeCmd]
       * bool: false
      [winterTag]
      [minInterval]
       * number: 30
      [openingValveTime]
       * number: 60
    [pumpState]
     * table:
      [after]
       * table:
        [lastupdate]
         * number: 0
        [name]
        [value]
         * bool: false
      [before]
       * table:
        [lastupdate]
         * number: 59
        [name]
        [value]
         * bool: false
    [firstTimestamp]
     * number: 1540829612
    [valvesInSummer]
     * table:
      [1]
       * table:
        [value]
         * bool: true
        [firstTimestamp]
        [name]
        [opened]
         * bool: true
    [opened]
     * bool: true
[sleepDescription]
 * string: Calculated 60s
[season]
 * bool: true
[/size]
[size=undefined]
Circolazione mansarda 29.10.2018 17:14:33
* table:
[zones]
 * table:
  [1]
   * table:
    [info]
    [settings]
     * table:
      [pumpGA]
       * string: 2/0/2
      [summerTag]
      [pumpBeforeCmd]
       * bool: false
      [winterTag]
      [minInterval]
       * number: 30
      [openingValveTime]
       * number: 60
    [pumpState]
     * table:
      [after]
       * table:
        [lastupdate]
         * number: 0
        [name]
        [value]
         * bool: false
      [before]
       * table:
        [lastupdate]
         * number: 60
        [name]
        [value]
         * bool: false
    [firstTimestamp]
     * number: 1540829672
    [valvesInSummer]
     * table:
      [1]
       * table:
        [value]
         * bool: true
        [firstTimestamp]
        [name]
        [opened]
         * bool: true
    [opened]
     * bool: true
[sleepDescription]
[season]
 * bool: true[/size]
RE: Resident script pump circulation - by Domoticatorino - 29.10.2018, 16:37
