AHU MODBUS TCP VALUE
Thanks for your help, I got the script to work today. When I contacted AHU, I realized that it was the wrong values I received. There were inputs 95 and 96 that I needed to compare.
Here is the final working code:
require('luamodbus') if not mb then    mb = luamodbus.tcp()    mb:open('192.168.201.53', 502)    mb:connect() end openvalue =  grp.getvalue('6/3/1', dt.uint8) tfvalue = mb:readinputregisters(94, dt.uint16) -- 3x0095 Supply air flow ffvalue = mb:readinputregisters(95, dt.uint16) -- 3x0096 Exhaust air flow if tfvalue and ffvalue == 0 then   openvalue = 0 end if tfvalue < ffvalue then   if openvalue < 220 then     openvalue = openvalue + 25   end end if tfvalue > ffvalue then if openvalue > 25 then openvalue = openvalue - 25 end end grp.write('6/3/1', openvalue, dt.int8)
it was as simple as that. Big Grin
AHU MODBUS TCP VALUE - by Elmyran - 01.11.2018, 19:42
RE: AHU MODBUS TCP VALUE - by CHOUAIBOU - 01.11.2018, 21:10
RE: AHU MODBUS TCP VALUE - by admin - 02.11.2018, 08:17
RE: AHU MODBUS TCP VALUE [solved] - by Elmyran - 02.11.2018, 20:22
