MQTT lib references? enable TLS for use with AWS
(23.11.2018, 19:18)Erwin van der Zwart Wrote: Hi,
In folders or direct on root?
folders exactly as i mention..
I had to create these folders path is /home/ftp/
i just tested again and its the same also i have to change directorys with cd in the FTP terminal....
the code looks like this....
broker = 'awsarn' cafile = '/home/ftp/cafile.crt' certfile = '/home/ftp/cert.crt' keyfile = '/home/ftp/private.key' client:tls_set(cafile, nil, certfile, keyfile) --client:login_set("undefine",jwt) --GCS not working also client:connect(broker,8883)
RE: MQTT lib references? enable TLS for use with AWS - by juanpalf - 23.11.2018, 19:24
